Five in a Row - tyronet2000
A fine start.
A couple of ideas .... I'd be tempted to trim off the top a bit - the open sky area doesn't add anything, so I'd crop in near to the waterfall top, and perhaps you could lose a bit at the bottom also?
I'm not sure if you've cranked things up on the computer, but the highlight levels on the rock faces look a bit OTT, kind of artificially lit. I think you could pull down highlights on these areas (but NOT on the water!) selectively to give a more natural muted result. Be careful not to let the shadow levels drop as well though.
Another great watery photo!
If I were to crop, I'd perhaps take half a centimetre from the bottom. I think that fragment of sky adds useful context.
I like both, but with a slight preference for the 2nd. Like Barrie and David, I find the first a little dark on both my desktop and laptop, but I like the composition and the space around the big rock.
In the second - I'm with Simon, just a tad off the bottom to remove the light rock just left of centre (is it under the surface of the water?). I also agree that you need the bit of light at the top for context.
Phil
My Flikr Page link
#2 will look better with that bit of rock cropped off, surprised no one mentioned the whitish lumps of foam at the right. So on to #3 tomorrow.
Northumberland
1. Boulders at Bamburgh K5IIs 18-135mm @ 68mm f/22 1/3 sec ISO 100
Stan
