The dreaded K30 aperture motor failure strikes again
Do you have a link to the online manual, please?
Detailed instructions of how to strip down the K-30 are given on the Penta-Club site.
Use Google Translate ....
http://www.penta-club.ru/forum/topic/137296-%D0%BF%D0%BE%D0%BC%D0%BE%D0%B3%D0%B8%D1%82%D0%B5-%D1%81-%D0%BA30/page__st__180
Regards Dave
Looks like someone has acknowledged the issue at last!!!
Good luck.
Perhaps those of you with this Pentax problem could look at banding together and approach Johnson's/Pentax en masse for a resolution to this issue?
Those problems that made for lengthy forum threads are actually minor and only have affected a very small percentage of cameras. All camera brands have had their 'issues'.
It is way too soon to know if the K-70 will throw up a problem which might affect a dozen or two users, it's highly unlikely that the same mechanism used in the K-30 would still be used four and a half years later.
Add to that the number of users on here compared to the number who have posted about an issue and we get a very low failure rate. As mentioned before, Pentax had the best reliability result in a quite extensive survey that was published a few years ago. As Steve says, all marques have problems from time to time and most have more problems than Pentax.
That and the mirror flop saga are the only major issues I'm away of with Pentax cameras in recent times. That position is worth protecting .
When you've got camera's failing within their two year warranty period, you've got a problem that's not going away. Burying their heads in the sand over it doesn't send a very positive message about being valued as customers of the brand.
And failing within the warranty period or after the warranty expires is just academic.
Lancashire
