Wireless trigger for studio lights
Posted 08/03/2011 - 11:16
Don't confuse Infrared with the near infrared that some flash guns use for autofocus assistance. They are essentially small flashguns that emit IR which is invisible to the human eye. It is impossible for a wireless trigger to harm your camera.
Posted 08/03/2011 - 11:20
johnriley wrote:
Your remote control for the television use them as well and the Wii remote so if it wasn't save...
Decided against IR in the end as I wanted to avoid the IR beam as we do some newborn shoots and parents stress enough over the lights
You can't see the IR beam. Only the dullest of light emanation if you look directly ar the transmitter.Decided against IR in the end as I wanted to avoid the IR beam as we do some newborn shoots and parents stress enough over the lights
Posted 08/03/2011 - 11:33
Anvh wrote:
Indeed, plus they should worry about any heat sources too, such as people, radiators, the sun, electronic devices and the baby itself.johnriley wrote:
Your remote control for the television use them as well and the Wii remote so if it wasn't save... Quote:
Posted 11/03/2011 - 20:46
after ordering my triggers managed to get a work around today. Flash on hotshoe in manual mode, minimum power, pointing straight up at cieling. No pre flash andsynchs perfectly with the stusio lights
Posted 11/03/2011 - 21:48
Glad to hear they work
Posted 11/03/2011 - 21:53
In manual mode what shutter speed are you attaining ? mine will only work at 1/90th .
regards, tim.
regards, tim.
Posted 11/03/2011 - 23:11
I was about to say that this was the cheapest and most effective option!after ordering my triggers managed to get a work around today. Flash on hotshoe in manual mode, minimum power, pointing straight up at cieling. No pre flash andsynchs perfectly with the stusio lights
But you beat me to it.
I point one of my AF500s at the ceiling, on 1/16 power. It always works, and the light it produces is a mere fraction of what is coming out of the Bowens.
Posted 11/03/2011 - 23:21
I think he's saying he's just using a flash head Stefan !? not triggers (on order I believe)
K-7 | K10 | DA 18-135 | DA 18-250 | DA 55-300 | DFA 100 |
Posted 12/03/2011 - 15:37
Cisco wrote:
Yep
I think he's saying he's just using a flash head Stefan !? not triggers (on order I believe) Glad to hear they work
Posted 13/03/2011 - 09:55
regards, tim.
Was synching no problems at 1/180th. Could not try any faster as even in manual mode as the flash was on it would not let me go faster.
regards, tim.
Posted 13/03/2011 - 16:02
The max sync speed of the camera is 180th. I think Tim is referring to his radio triggers.
Posted 13/03/2011 - 16:10
The RF-602 wireless trigger only works reliably at 1/90th. Sometimes you get a black band at the bottom of the pic at 1/125th. Good unit though because it can also be used to fire the shutter from up to 100M away.
Posted 13/03/2011 - 16:18
are the 'RF-602' a bit crap then ?? my RF triggers work fine at 1/180 !!
24 years
Tyldesley,
Manchester
