Pentax Full Frame, Will it ever happen.
This topic has a poll - login to enter
Smeggypants
Posted 21/05/2013 - 15:05 Link
Frogfish wrote:
Smeggypants wrote:
Sorry I meant cms not mms. Too late to edit the post now ! So as I said put your fingers together and see what 1cm is in actuality, it's really nothing. It's 90g on Snapsort but whether 90g or 110g ... again it's piddling and not even worth debating.
For all intensive purposes there is nothing dimension & weight-wise between an APS-C K5ii and a full frame D600.
Well there is a significant difference in size between the K-5 and D600 and in spite you saying "Photos can lie" ( which of course can sometimes be true ) the comparison photos here
http://camerasize.com/compare/#187,378
are not lying. The ratio of the images is the same as the ratio of the dimensions quoted.
But there's really no need to make disprovable claims about the sizes of cameras ...
So what do you mean by that ?
Exactly what it says
I have given the dimensions twice in this thread (the first time in cms the second time mistakenly in mms) and you, who does not own a D600, are trying to tell me (who has owned both, even at the same time) that because 'you have seen it on the internet' you must be right ?
There is only one answer to that, until you have been and held them side you side you are not qualified to lecture me on the reality.
I'm perfectly qualified to look at two images, measure the ratio of those images and compare that ratio to the ratio of the dimensions given beside those images. Are you claiming the photos are the wrong size or the dimensions published are incorrect?
If these image and dimensions are correct then owning or holding the cameras in real life is irrelevant. Most people would says there's a significant different in size between the K-5 and D600
The irony of that is that you are publishing your subjective opinion... wait for it .... on the Internet!
Dodge69
Posted 21/05/2013 - 15:26 Link
Another hypothetical FF thread, yet practically nobody 'Needs' it? LOL! If I was in the PRIC management team this Poll would not be encouraging me to write cheques for FF R&D.
How many of the 'Wants' are just dreamers and how many will fork out the cash when it comes to the crunch?
Perhaps if your white knuckle wishing for a FF just so you can pixel peep on your computer screen, you hardly if ever actually print your shots, much less at the sizes required to take advantage of FF - then maybe you should give yourself a good slap, and while your at it take your current DSLR out and try and get the shutter count into at least 5 figures.
Pentax pour des images riches en détails!
Smeggypants
Posted 21/05/2013 - 15:30 Link
Pixel peeping for all it's irrationality actually keeps the Photography industry afloat
K-5IIs anyone?
MarkTaylor
Posted 21/05/2013 - 15:31 Link
Smeggypants wrote:
The D600 is 10mm wider, 16mm taller and 9mm fatter than the K-5, and 110g heavier according to.
Or in my terms, a finger wider and fatter and good 'thumb plus' taller. I have small hands. I've held all sizes of camera and found I'm not too comfortable with the larger ones. However I do believe it's rather subjective. Some folks on this forum have said they find the K-5 too small to grip comfortably. Another person might be equally comfortable with the large and the small, and not notice the difference nearly as much.
Smeggypants
Posted 21/05/2013 - 15:37 Link
I just looked up the dimensions of the K-20D and that's smaller than the D600 ( Although about the same width ) and I noticed an appreciable difference between the size of the K-20D and the K-5. I remember many Pentax shooters commenting on this as well.
Frogfish
Posted 21/05/2013 - 15:42 Link
Touche Smeggy
MattyH
Posted 21/05/2013 - 16:35 Link
Pentax Full Frame Camera to be launched in last week of October this year
Or not
Algernon
Posted 21/05/2013 - 16:48 Link
Or not
Halloween! .... Will it have a built in broomstick!
MattyH
Posted 21/05/2013 - 16:55 Link
Algernon wrote:
Or not
Don't think so, as it will make it a touch bigger then a D600, And we don't need to go down that road again
Edited by MattyH: 21/05/2013 - 16:56
MattyH
Posted 21/05/2013 - 16:58 Link
Toshiba, Not Good
Dodge69
Posted 21/05/2013 - 17:06 Link
Smeggypants wrote:
[quote:3496ace15f="Dodge69"]
K-5IIs anyone?
LOL indeed, guess that just about sums it up
JAK
Posted 21/05/2013 - 17:15 Link
What information do you have to suggest it will cost more than a K-5IIs then, or is that just a presumption?
It might easily just replace it in the market position and the K5II(+s) move down to the slot presently occupied by the original K-5.
JAK
Posted 21/05/2013 - 17:19 Link
True, very true.
If it does appear roughly the size of a D600 then I'm sure no one would complain, but Pentax have often gone down the route of being able to brag about being the smallest and lightest.
Dodge69
Posted 21/05/2013 - 18:01 Link
Uhh, and educated presumption I suppose. LOL what cheaper than a D600? That's dreamland optimism for sure. I would presume a new Pentax FF, their first ever, is going to come out at the sort of premium price it's tiny market share would warrant. Up around Sony A99 territory easily.
JAK
Posted 21/05/2013 - 19:24 Link
Er, not quite. Google Pentax MZ-D or click this link.
