More painted Pentax.!
[IMG]http://i183.photobucket.com/albums/x21/Kingofthemountains/IMGP3744.jpg[/IMG]
Will be getting a film test as soon as the new light seals arrive.
seeing as that prism you sent me fitted ok I have a 'spare' spotty f which I bought after being told it wouldn't. Mat have to give that a lick of colour in the next few weeks
The top plate had a nasty dent on the prism housing. It straightened out pretty well, but you can still see ripples, where the metal stretched.
It's a nice colour tho', eh!... Saab blue, with two coats of clear lacquer.
Backhouse.
I think your Spotty F will look nice in..... Custard yellow!
Mowog.
The base plate was fine with a good rub down with fine abrasive paper and a few thin coats of orange enamel, the only problem was with getting paint to stick to the plastic.
or something really bright with a pearl fleck to it
I foresee a visit to Halfords in the near future.
I hope others feel the same, when I put these three on ebay, soon. I think they will either get much higher prices than unpainted ones, or much lower. It's going to be fun to see!
Mowog.
I think there is a Japanese chap, who does make a living from repainting Leicas... To a very high standard, though.
Mowog.
Interested of Bromborough
The blue spotmatic looks super and Dangermouse, I recognise that orange, Land Rover G4 by any chance :
The clear laquer is a total must as paint is actually very soft and fragile and its only 'finished' and more hard wearing after the laquer has been applied. If I ever spray anything its always a must, minimum 2 coats
I rather thought that enamel would be ok without laquer, it seems to be more of a problem with adhesion than with keeping the stuff on. I may well do a black K1000 in future, that would be simpler as with the metal panels I could give it a proper rub down, prime, spray and laquer just as I did with my alloy wheels. The laquer would be applied after the white lettering had been reinstated.
The MES has been re-sealed and now has a roll of HP5 loaded, I'm just hoping that it isn't suffering from the shutter-fails-to-cock disorder as I have a suspicion that on a couple of occasions I've wound on and nothing has happened. Then again, I've fired the shutter 40 times in succession without a film and had no problems. Hopefully it won't play up now, or at least if it does when I try to wind the first frame on I can still remove the film and avoid wasting it.
T
London.
These were done during the last couple of weeks.
A metallic blue SP1000.
And a matching little friend.
Black K1000.
I did a black K1000 last year, but it was rubbish! This one turned out much better.
C'mon People... Join in. Let's make this a long and colourful thread of tarted-up Pentaxes.
Mowog.
