K20D vs K-X
Posted 18/11/2009 - 07:51
Using two cameras together it's useful if they are the same and the K10D and K20D are essentially the same. That's what I'd go for.
The newer technology won't make that much difference but faster handling might, IMHO anyway.
Posted 18/11/2009 - 08:43
It depends on how you use the K10D, ie; settings and controls etc. The K10D is a pro-spec body with features that you will not find on the Kx.
As an example, do you use both the front and rear control dials on the K10D? if so then your going to feel lost with a Kx.
I'd go for the K20D
I'd go for the K20D
Posted 18/11/2009 - 08:49
I'd go for the K20D
Seconded.It depends on how you use the K10D, ie; settings and controls etc. The K10D is a pro-spec body with features that you will not find on the Kx.
I'd go for the K20D
Posted 18/11/2009 - 10:37
Go for the K20D or even push the boat out and get the K7.
Simon Hopkins
Spectral Photography
Posted 18/11/2009 - 13:35
I have just been through the same debate with myself and opted for another K20D because :-
a) it is weatherproof
b) it uses the same grip and batteries as my other bodies
c) the controls are exactly the same as my other bodies
So I would recommend you go for the K20D.
Hyram
Posted 18/11/2009 - 16:05
I'd go kx..
adds video to the mix, if you got flash units you already got spare rechargable batteries.
but I guess the main question for you would be weathersealing vs video...
which do you need more?
Posted 18/11/2009 - 17:37
Remember that the kx is new and massively overpriced compared to the opposition. Also, it's a revamp of the km horror and bits of it don't really work such as the poorly implemented video, unusable live-view and battery problems.
At least wait a bit until it either it bombs and the price drops massively (like km) or the opposition makes a much better item for the same or less money.
At least k20 worked properly and was reasonably well designed, if a bit plain vanilla.
Posted 18/11/2009 - 19:25
Viewfinder,
Why is that you post only to denigrate Pentax products?
Dave
Dave
Posted 18/11/2009 - 19:33
ignore him, perhaps he'll go away
but it does help
but it does help
No contest
Posted 18/11/2009 - 19:52
Jack your flashing emoticon is quite annoying you know
About the cameras... I don't know, haven't tried the K-X yet so can't comment on that.
Posted 18/11/2009 - 19:58
It got your attention then, OK Stefan I will remove it just for you,
you don't have to try the KX just check the specs
Posted 18/11/2009 - 20:34
Jack, the problem is that it was flashing other then that it was splendid.
Maybe replacing it with something else would be better.
Didn't had an comment on my emoticon so far, but if there are problems please say so.
The specs don't say everything Jack.
I've no idea how the camera handles, that's my concern at the moment.
My uncle is going to get the K-X soon with the two kit lenses, would make a small report about it when I've tried it out.
Denver, CO
K20D, K-7,
Pentax 18 - 55mm, 55 - 300mm, and Sigma 170 - 500mm lenses.
