Catch in focus- wow!
Pentaxophile
Posted 26/06/2011 - 12:59 Link
I have only just worked out how to set up Catch in Focus on my K7. What a terrific feature, I can't believe I haven't tried it before! Now my manual lenses seem like AF lenses, with my fingers doing the work of the AF motor of course. Another benefit is there is less chance of movement blur from pressing the shutter button
Anyone else using this, and is it unique to Pentax?
JamieT
Posted 26/06/2011 - 13:09 Link
I agree, excellent feature. On the KX I understand it is limited to focus in the centre of the scene though, not sure if the K7 is the same? Really does help with camera shake as you say.
K5, LTD 15 SIG 30, SIG 105.
Don
Posted 26/06/2011 - 13:18 Link
I use catch in focus all the time... here is a trick to try (only for those with a cable release):
set your camera up in front of your fish tank or a nice setting you'd like to photo your cat.... set it all up, lock your cable release so the camera will fire when the subject is in the frame, then use a laser to lead your subject into the frame... (yes fish will chase a laser just like your cat..).
mujirushi
Posted 26/06/2011 - 14:02 Link
I have been trying to use 'Catch in Focus' feature on my K-5, however can't seem to get it working...
Mind letting me know how you get it working?
Still learning!
Zooms: DA12-24 | DA16-45 | DA*50-135 | DA55-300
Primes: FA31 | DFA100WR | M50F1.7
Fun: LensBaby Composer + Kit
Don
Posted 26/06/2011 - 14:07 Link
you need a manual focus lens. if you use an "AF" lens you need to tape over the electrical contacts with scotch tape. you then set the focus manually, set the camera body to AF and press the shutter or lock your cable release open and when the subject is in focus, the shutter will fire... but the shutter will not fire UNTIL something is confirmed to be in focus by the camera.
JamieT
Turn it on in the menu, point at your subject and slowly turn the focus ring, when the object comes into focus the shutter will fire.
geclinke
Posted 26/06/2011 - 15:04 Link
I assume it works on the k5 with an autofocus lens if you switch the camera to manual focus, and / or flick the focus switch on the lens?
k5, 50mm FA, 18-55mm Kit, 50-200mm DA, 15mm Fisheye Sigma, 10-17mm DA Fisheye, 18-55mm DA WR, DA* 60-250, DA* 16-50
Pentaxophile
Posted 26/06/2011 - 15:46 Link
I don't have any lenses like that to check, but I can't see why not. Actually my Tamron 90mm is supposed to have an AF/MF switch, but still autofocuses when set to MF!
Edited by Pentaxophile: 26/06/2011 - 15:49
geclinke
Posted 26/06/2011 - 16:44 Link
Aha, just tried it. With a DA* it does work when the camera is set to af, and the lens set to mf. I assume that means it'll work for any DA* lens, and maybe any other af lens with an mf switch - except maybe a tamron 90mm
Hardgravity
Posted 26/06/2011 - 17:20 Link
It's an old part of the Pentax software is 'catch in focus', if my memory is correct it goes back as far as the SF7 film camera!
Very useful it is too.
Cheers, HG
PPG entries.
Edited by Hardgravity: 26/06/2011 - 17:20
Mike-P
Posted 26/06/2011 - 17:23 Link
Great for macro ... set lens focus to full magnification, depress shutter button and move camera back or forward slowly.
Click ...
Algernon
Posted 26/06/2011 - 18:06 Link
It was part of the feature list of the Power Zooms.
Minolta also had PZ's but I don't know if they also
had CIF?
Edited by Algernon: 26/06/2011 - 18:07
Blythman
Posted 26/06/2011 - 20:04 Link
Yes HG, used it regularly on my SFXn
Alan
Smeggypants
Posted 27/06/2011 - 02:50 Link
Very useful feature,
IIRC it should work with any lens when AF is turned to manual.
Great for self portraits or catching the dog(s) stealing food when you're out of the room.
JamieT
Posted 27/06/2011 - 09:02 Link
Good ideas those smeggy. Might have to put some treat on top of the camera and see what happens!
