Using SSD Drives
tyronet2000
Posted 19/10/2015 - 15:52 Link
As the price has dropped quite a bit now are these drives of use for more than just booting the computer more quickly? How do they fare in say booting windows and photo editing for instance running Lightroom. Looking for info on the long term life of so any input appreciated
Stan
truckerathome
Posted 19/10/2015 - 16:20 - Helpful Comment Link
I use a Samsung SSD 850 EVO 500GB hard drive with Windows 10 and it is definitely a lot faster to boot to the system and working with programs like Photoshop etc than my old hard drive, whether windows 10 has helped on that as well, I do not know.
I use my old hard drive plus one other as extra internal drives for photos etc so as to keep the SSD for use with windows and programs. The Samsung drive comes with its own optimisation program to keep the hard drive configured and in top condition for use. Life-wise they are reckoned to last a lot longer than conventional drives as there are no moving parts (platters etc) but it appears only time will tell on that issue.
Having mine in use for a few months with no issues and the speed increase all round, I would advise anyone to get one if they are looking to change hard drives. They are still a bit pricey for the larger hard drives but as you say they are coming down in price slowly but surely. I think the extra price on top of a conventional hard drive is worth it. It was in my case anyway.
tyronet2000
Posted 19/10/2015 - 16:53 Link
Thanks Martin, just the sort of feedback I was looking
Stan
Tyr
Posted 19/10/2015 - 19:47 - Helpful Comment Link
I fairly recently went from HDDs to all SSDs.
My old machine had a 64GB SSD (60GB usable) but an old model which was fast compared to a hard disk but slow compared to modern SSDs. I used it as a boot drive and stored Photoshop and Lightroom on it. Any photographs were stored on a RAID0 array with 2x100GB 2.5" 7200rpm HDDs. This was horribly slow to load even pre-rendered images.
I did a side-grade on my PC changing to a similar power processor but with a higher bus and therefore RAM speed and SATA-III connections on the motherboard. I then went from 60GBs of SSD space to 1.2TB. I now have no slow downs at all and loading times are very small.
I chose SSDs that have a performance profile designed for long sustained loads without slowing down. Some will rapidly deteriorate after just 10 minutes of usage and their I/O rate will drop to a fraction of the advertised rate. The IOPS on most drives will drop from 80-100kiops to about 7kiops (Samsung 850s included). The ones I chose remain at 20kiops even under long sustained loads. Similar thing happens to response times, going from 3ms to 20-60ms depending on the drive where as the ones I looked at remain below 14ms.
It may not seem like much but if you are working for 4 hours or longer on mand GB of photos then it will make a difference. If you only work about 1hr at a time on fewer files then you won't notice as big a difference between drives.
There is nothing special in terms of market segment or price of the drives I chose. They were the cheapest per GB that I'd ever seen an SSD, which is why I got 3 of them and a low end model to boot. But they are consistently well performing even though their peak numbers are lower than other drives. I'd definitely recommend the OCZ ARC-100 drives (not the Triton drives, they are sadly very slow and the same price per GB as the ARCs).
I've reduced their capacity to 400GB on each as they have 447GB usable space. Some of the 480GB that isn't usable is already set up for improving performance and longevity but I added 47GB on each drive to this 'over-provisioning' to extend the lifespan and improve performance further. 10% makes a difference but 25% is best for performance. I can't quite afford to give up 25% of each drive though as I need the space.
richandfleur
Posted 19/10/2015 - 22:24 - Helpful Comment Link
SSD's are great. Single biggest performance gain you can get for the money.
Won't help with number crunching ability, but everything starts much quicker and feels much nicer to use.
One for the OS, one for the data.
Tyr
Posted 20/10/2015 - 11:12 Link
Forgot to add, after SSD the second best thing I did was to get 16GB of RAM. The processor I have is not really that fast (AMD Athlon X4 860K Black Edition) but the high bus speed, and loads of high speed RAM makes a big difference.
sf
Posted 20/10/2015 - 11:30 - Helpful Comment Link
SSD is definitely the way to go, though be sure to back up any essential data (the images themselves, Lightroom's catalogues, etc.), to something other than SSD. For all their faults, it's often possible to rescue data from a failing mechanical drive, whereas if your SSD dies, everything on it is likely gone forever.
Algernon
Posted 20/10/2015 - 12:23 - Helpful Comment Link
Intel CPU's perform much better than AMD on Lightroom and Photoshop. It would be a much bigger boost than more RAM...
http://uk.hardware.info/reviews/6094/15/amd-vs-intel-57-processor-megatest-bench...
I've got an SSD, but I'm happy with a 2.5" 1gb 7200rpm Hitachi as the main drive almost as fast.
Some people have reported a massive increase in their PU posts after switching to SSD
tyronet2000
Posted 20/10/2015 - 14:19 Link
Hi Algi. I knew you would have some invaluable input
Stan
Tyr
Posted 20/10/2015 - 14:38 Link
I know but for £55? The i5 or i7 I wanted would have been £180/250ish. They literally perform operations twice as fast as what I have but for the price I cannot complain. And for the difference in price I got myself a motherboard and RAM thrown in as well.
I'll definitely look to get something faster later down the line. But at the time it was all I could get.
tyronet2000
Posted 20/10/2015 - 16:27 Link
Just had a look on Amazon and it looks like the Samsung update has been a disaster Not sure if it's been resolved
Stan
robbiec
Posted 24/10/2015 - 17:44 - Helpful Comment Link
Problem with SSDs is that once you start with one, then you want two. Its like LBA for flash drives
Nippy though but always have a backup setup - I run 4 * SSDs in RAID 0, daily backup to 4 * 2TBs Mechanical in RAID 5 and then once a week I do an external backup as well. Pure paranoia but you can never be sure.
The new M.2 devices are exceptionally nippy, have a browse for Samsung 950 PRO , if you have or are thinking of upgrading your CPU / Motherboard, check to see if it supports M.2
tyronet2000
Posted 24/10/2015 - 22:09 Link
Thanks robiec. As far as I know the only paranoia in computing is the dreadful panic when things aren't backed up and the drive dies. I have heard just before a drive dies they emit a high pitched whine only audible to dogs and those about to lose invaluable data
Stan
stub
Posted 25/10/2015 - 00:10 Link
Once you install an ssd in your computer there is no going back to tradional hard drives except for data storage. I agree that if your looking at speed an Intel processor is worth looking at first. Ive had my ssd for 2 years now. I would never go back to the older hard drives except for data storage.. Over the years I have had many traditional hard drives die on me. They are far too unstable..
Stuart..
pentax
Posted 25/10/2015 - 11:23 Link
Hi I updated my PC with a Seagate hybryd ssd/hd which improved the speed it cost about £60 for a 1tb from cclonline computors.
Derek
Edited by pentax: 25/10/2015 - 11:25
