Room for improvement C&C
Posted 04/03/2010 - 13:35
I think compositionally it's pretty nice. It does look a bit soft, though which is surprising given 1/60th second and F/16. Is there a lot of JPEG compression? What sharpening did you do, if any?
GX20; DA 17-70 F4; 18-55 kit; Ricoh 50mm F2; Vivitar 75-205mm F3.8
Posted 04/03/2010 - 13:39
The image looked ok before I uploaded it to Photobucket, it does seem to have softened it considerably.
Posted 04/03/2010 - 13:56
I like it. Put it on a calander. As for improvements Bikini clad wrestelers LOL.
Steven
Steven
Posted 04/03/2010 - 14:38
I think bikini wearing wrestlers may suffer from hypothermia on my coastline
Posted 04/03/2010 - 15:22
I does look a little soft Graham but the compresion in Photobucket may be to blame. The quality of the light in the photo is excellent which makes it a very appealing picture. I wonder if you worked a little on the contrast of the mud bank in the foreground and tweaked the glint on the boats whether it it would give the picture added impact.
david
david
Posted 04/03/2010 - 15:59
Graham I hope you don't mind, did a quicky.
A tritone was what I had in my mind, what do you think, black, blue and yellow/orange.
[IMG]http://i282.photobucket.com/albums/kk244/Anvh/_IGP7151v2x.jpg[/IMG]
Posted 04/03/2010 - 16:44
My fear is that the burnt out area on the right will always prevent you from making this work. You do have two strong triangles and the rectangle of the sky but the sky isn't strong enough as it stands. Have you tried selectively darkening the sky to see if that helps? I suspect it will just end up looking odd. I think you were between a rock and a hard place as the bright sky needed the correct exposure but that would kill the foreground. You can't exclude the very bright area because then you lose the points of the triangles.
Personally I'd move on to something I could make work.
Now watch as someone steps in and does a wonderful job on it!
Posted 04/03/2010 - 17:03
Posted 04/03/2010 - 17:05
Mike, something like this?
It's hard not to kill something, if you push it you will kill the contrast for sure.
The blue is a feature though and I can remove the saturation if that's better, also this done with a low quality JPG with a RAW file you can recover a lot more.
[IMG]http://i282.photobucket.com/albums/kk244/Anvh/_IGP7151v2x2.jpg[/IMG]
Posted 04/03/2010 - 17:10
@ Stefan. Nope that's still got that terrible burnt out area which without some very clever cloning will always be its main weakness. The sky is tending towards funny looking as well.
@ Malo - nice work on the sky etc. but you've lost the point of the composition surely which was the convergence of the triangles.
I wasn't going to say it but I bet Graham was standing up when he took this. Even in my decrepit state I think I would have got lower and either had a lot more sky or a lot less sky. If it was a zoom lens then I blame that as a prime would have got your feet muddy for you
Move on I say!
Move on I say!
Posted 04/03/2010 - 17:40
Even if you clone it out you've the problem the reflection isn't working so that would mean you need to clone out everything of the photo
Posted 04/03/2010 - 18:24
Somewhere at the back of my mind
