Problem with k5
Posted 11/01/2013 - 13:50
You may need to post a photo to show us exactly what you mean.
If you use a polarized filter it can create banding at wide angles.
George
George
Posted 11/01/2013 - 14:13
I sent a photo to gallery . You can check my portfolio. By the way I do'nt use filter.
thank you for youre attention and help.
Posted 11/01/2013 - 14:34
Not sure what's causing it. Are you shooting in raw or jpeg? What processing are you doing to the file and what software is being used? I vaguely remember someone having similar problems that was caused by the software (settings) being used.
George
George
Posted 11/01/2013 - 15:02
I am shooting in raw and this shot and other shots with this problem are without processing.
Posted 11/01/2013 - 15:07
There must be some processing for it to be converted to JPEG.
Posted 11/01/2013 - 15:15
As in another thread, over-processing of JPEG files can also cause banding.
I have had the same banding issue a few times when re-sizing images. What software did you use to re-size the image? If you are using Photoshop (or Elements, though I'm not sure if Elements is the same, as I have never used it), then make sure you select Bicubic Sharper when reducing the size of the image.
Posted 11/01/2013 - 15:22
When I shoot and see the files in my camera directly,this problem exist.
Posted 11/01/2013 - 15:28
If its in camera isnt this usually a memory card problem???
Concert photography
Concert photography
Posted 11/01/2013 - 15:43
I do'nt know.Is it possible?
Posted 11/01/2013 - 16:03
I had a similar problem within a week or two of getting my k20 d, I sent it back to JP who just reinstalled the firmware, had I known, of course, I could have done that myself.
Posted 11/01/2013 - 16:15
I think, I must sent it back too.
Posted 11/01/2013 - 19:03
Before you do that why not post a RAW file for members to have a look and and try with different raw converters. I see it it too when I zoom in on the LCD screen sometimes and I have done so with previous different cameras, all of them I think. Once it goes through the raw converter it disappears.
Iran
