Pentax 16-85mm aperture arm return spring replacement
Posted 22/09/2021 - 19:33
As mentioned on the other thread, just get a similar sized spring from broken bits and pieces, or maybe try a DIY shop.
These guys apparently make springs
https://www.airedalesprings.co.uk/
All the gear with no idea
Posted 22/09/2021 - 20:42
Posted 22/09/2021 - 21:28
I have used this company in the past,
https://www.coilspringsdirect.com/store/entex-tension-springs
Paul
Posted 23/09/2021 - 09:06
I've successfully made this sort of spring using a retractable biro's spring, cut to length and the final turn at each end bent to the correct angle using small plies.
Hope that helps.
Hope that helps.
9 years
The North
I am looking to buy a Pentax 16-85mm aperture arm return spring. Its tiny and mine broke but I,m looking to replace it myself as its easy. Can anyone recommend a parts retailer that could help out??
Thank you in advance
