Missing EXIF data
Posted 25/05/2015 - 11:46
My edit software appears to lose EXIF data too Barrie as with some of the photos on my gallery and entry for this month's competition. Any thoughts would be welcome.
David Hamilton
Posted 25/05/2015 - 11:47
There are problems with the way the site displays some EXIF data, but the solution is apparently quite complex. IT are aware of it.
Posted 25/05/2015 - 11:59
Thanks John.
It sounds as if the Pentax Photo Gallery may be a separate issue then.
Barrie - Too Old To Die Young
Posted 25/05/2015 - 12:32
Pentax Photo Gallery is not connected to Pentax User, so it is indeed a separate issue. Only they can answer for PPG.
Posted 25/05/2015 - 13:33
I'm aware of that John, but there was a common denominator in me and the editing software.
So if anyone else has had a problem with PPG, I'd would be glad to here about it
Posted 25/05/2015 - 16:33
Hi Barrie, have you updated to Lightroom 6.0?
Regards, Tom
K-1ii,K-3iii's.
SMC PENTAX-F 1:2.8 28mm, HD Pentax-D FA* 1:1.4 50mm SDM AW,
SMC PENTAX-D FA MACRO 1:2.8 100mm WR,
SMC PENTAX-DA* 1:4 300mm ED [IF] SDM,
SMC PENTAX-FA* 1:4 600mm IF & ED,
HD PENTAX -DA 1.4x AW AF REAR CONVERTER,
K-1ii,K-3iii's.
Posted 25/05/2015 - 17:45
Hi Tom, Yes Lightroom 6 and Elements 13
Posted 25/05/2015 - 18:01
Guessed you were using Lightroom 6.
You might find this link useful to both problems - link
Lightroom 6 inserts more metadata info than Lightroom 5 so the websites are not reading the correct field!!
Email also sent.
Email also sent.
Regards, Tom
K-1ii,K-3iii's.
K-1ii,K-3iii's.
Posted 25/05/2015 - 18:24
It's probably not this site. Adobe own you and can do whatever they like
Looks like they have stripped out the MAKER INFO and put in at least 500 lines
of their own mush
They've even removed the 'shutter count'
Write to them very nicely and ask them if you can have your camera back
of their own mush
The result of following your link
This is not your report and hence you cannot view it
Posted 25/05/2015 - 19:53
Thought that might happen as it was my report to PentaxuserThe result of following your link
This reply from PPG might be useful -
"Thank you for sending more details about your issue. We were able to come up with a solution for you. Lightroom 6 files contains more metadata info than Lightroom 5 files. When you upload Lightroom 6 jpg, the website is not reading the correct field. The solution is to modify the Exif data before you upload the image. We installed a software from the app store named **Photo Meta Edit ($3.99) on our mac. If you use PC, I'm sure there are software you may use for editing exif data. Open the file in Photo Meta Edit, look for the line with the tag name "Orientation". Right click on that line and choose "delete". Then, save the file. You should be able to upload your image after that. Give it a try and let us know how it goes. Thank you for using pentaxphotogallery.com. "
** One for windows users - "ExifCleaner"
Regards, Tom
K-1ii,K-3iii's.
K-1ii,K-3iii's.
Co. Durham UK
If you view the EXIF data you will see both Camera Make and Model are blank. Yet when I check with PhotoMe and Lightroom they both show Pentax and K5-lls.
I've also had a similar problem trying to upload images to the Pentax Photo Gallery, were the error message comes up "not a Pentax camera" but the EXif data confirms it was taken with a Pentax.
What am I doing wrong?
