Miranda 700 cd with Kx
Posted 13/03/2012 - 10:02
You cannot use a shutter speed higher than 1/180th with flash
How are you trying to fire the flash? on the hot shoe or on a cable or what?
Posted 13/03/2012 - 10:18
The 'limitation' on 1/180s has nothing to do with the flashgun - it is a physical issue to do with the shutter in the body. And, to be honest, it's rarely an issue in real world use.
(That said, the AF360/540 does support 'HS' mode which allows fill-in flash at any speed - but it works by 'machine-gunning' the flash gun at ultra high speeds.)
You use manual flash like this:
* Set the camera to 'M'
* Set a shutter speed slower than 1/180s
* Set the ISO & Aperture on the camera to match the flash settings
Note that the shutter speed has NO effect on flash exposure - it is just the ISO+Av. The shutter speed affects the balance between flash and ambient lighting
Check out the details on the sticky thred
Posted 13/03/2012 - 12:41
A quick question while your on the subject of Flash, I'm looking at a future purchase of a Metz 36 AF-5 Flashgun from WEX they are around £65. I'm looking but can't see if this will allow HS Mode.
I read that you kind of need this to freeze things like water droplets.
Not sure of my overall budget but i can manage £65 alot easier that £250+ for the Pentax AF 360 or 540 FGZ.
Will
Will
Pentax K-x, DAL f3.5-5.6 18-55mm,Pentax-A 50mm f2, DAL f4-5.6 50-200mm, FG360FGZ
Posted 13/03/2012 - 13:16
You dont need HS to freeze water droplets, flash duration which is, to most intents and purposes, the shutter speed can be as short as 1/30000th of a second.
HS mode is useful when using flash as a fill light in daylight when you have to use a shutter speed higher than 1/180th second
Posted 13/03/2012 - 15:05
As Ken said, you definitely do not need HS mode to freeze motion!
Pretty much any old flashgun will do - including the pop-up flash
It's all down to getting the ambient light balanced with the flash, and taking a LOT of shots to get the timing right
Do note, that the camera's shutter speed has no relation to the 'freezing' ability of the flash.
My advice - try your camera on "M", with the pop-up flash and experiment. Once you know where the limitations are, then you can purchase extra gear
Posted 13/03/2012 - 16:03
Thanks for the advice, the book i'm reading is the free one from this forum a few days ago on kindle. It menstions curtains and shutters. I guess it's still a good choice to get an external flash to offer bounce flash and reduce risk of red-eye, might just stick with the cheaper Metz as i'm still a noob. I'll hold off a bit longer and see what i can do with the built in flash.
Again Thanks.
Will
Again Thanks.
Will
Posted 13/03/2012 - 19:53
Hi guys thanks for answers;
I think i could not explain in detail. First of all, I have to mention that flash works as it should, when i press test button. How ever, it is another issue on thr camera. This is how I do it; I mount the flash gun via hotshoe. Then open the turn th flash and camera on. I set everythink in manuel. I set shutter speet 1/60, apeture to 5.6 and ISO 200. I adjust flash to exactly same settings. Then I shoot nothing happens. Flash does not fire.
what could be the problem?
Posted 15/03/2012 - 17:14
Any body there knows solution???
Posted 15/03/2012 - 20:46
This Miranda 700CD is a very old design and is either not compatible with current and recent Pentax DSLRs or is faulty. Either way, you should send it back and try to get a refund.Any body there knows solution???
In my view, your options are to save until you can afford to purchase a flash unit that will allow you to take full advantage of the features offered by the KX (prices start from around £50.00 in the U.K., for a very basic model such as the Metz AF-24), or buy secondhand. If you decide on the second-hand route expect to pay around £20.00, for which, if you are patient, you will be able to buy a Pentax AF-200T in good condition. This will not allow you to use the P-TTL capability of your KX, but it a very robust unit that can be used in auto-mode (on-flash sensor) and gives you manual control of the flash output (full or 1:1, 1:2, 1:4 and 1:, which, take my word for it, is a very useful feature to have and adds enormously to its flexibility and range of applications. NB the externally similar AF-200S does not share this feature and should, IMO, be avoided.
You can find more details about the AF-200T here: link and more about Pentax compatible flash units (new and legacy) here: link
Jon
Posted 15/03/2012 - 22:01
Jon
Jon thanks for answer but i am after some kind of cheap bouncing head flash. The reason for it is that i normally do not use flash in photography but when I am taking casual indoor shoot (birthdays etc) I need flash. The problem my wife alergetic to flash units. With direct foward facing flash units there is noway we can catch her eyes open. Melihbozkurt wrote:
Jon
So I need basic cheap bouncing unit to be used few times a year and i am not willing to pay more than 10 - 15 pounds for it as I will not use this my photograhpy.
Posted 15/03/2012 - 22:05
Pentaxophile wrote:
I used to have a Miranda 700CD - worked on my k200d. So not sure why yours isn't! I did 'upgrade' to a Cobra AF480 (for the princely sum of about 8 quid) which is more powerful and has a more neutral colour (the Miranda was a tad yellow).
Thanks for your advise, I will consider, if it continue to not to work.
Posted 16/03/2012 - 08:28
In my first post i asked 'How are you trying to fire the flash? on the hot shoe or on a cable or what?'
My problem starts here camera see flash, i cannot up shutter speed more than 1/180 which i can go up without flash. So everythink is normal but when i shoot, flash does not fire. Something is wrong in their communication.
I just wonder if anybody tried any of these flashes and managed to fire it?
Secondly, I just wonder, if there is any adjustment need to be done in camera to use manuel flashes?
Kind Regards,
Melih
