Longbow
Posted 26/05/2009 - 23:20
Mannesty wrote:
DIRTY SENSOR ALERT . . .
I was thinking that, but thought I'd cloned all the spots out. Which did I miss??DIRTY SENSOR ALERT . . .
What's the best way to clean the sensor, I only have a cheap blower at the moment. Just; mirror up and blow away?
Posted 26/05/2009 - 23:28
By eck! You've got keen eyes! You're not an archer yourself are you
Posted 26/05/2009 - 23:31
Slightly OT but related to it. I once worked for a company who were involved in testing the strength and elasticity of the longbows that were recovered from the Marie Rose, Henry VIII's flagship.
The exercise was shown in a TV programme, Time Team I think it was, with Tony Robinson.
Some of the bows were actually 'brought back to life' after bending and stressing them. They were re-strung and worked very well apparantly.
Posted 26/05/2009 - 23:35
Oh! I remember that!
Apparently they had a draw weight of about 140lb
The bow in that picture isn't mine, but I believe it has a draw weight of about 60lb and that is quite heavy these days.
I shoot a recurve bow with a 38lb draw weight, I can't imagine pulling 140lb
Posted 26/05/2009 - 23:38
No, I'm not an archer.
I think there may be another little dust spot immediately above the leftmost arrow.
Regarding sensor cleaning, I use a combination of Giottos rocket blower, and when necessary, the Arctic Butterfly from Visible Dust.
I would use a wet cleaning system only as a last resort since it took me absolutely ages to clear the smears from a *istD sensor after wet cleaning it.
Posted 26/05/2009 - 23:42
Thanks for the advice. Looks like I'll have to get a better blower.
Posted 26/05/2009 - 23:46
I think that at the time the TV programme was made, there were very few bowmen around who could actually pull them.Oh! I remember that!
All I know is that the longbow is effectively a laminate which gives it it's characteristics. Although it is cut from one piece of wood, the inner surface has to be good in compression and the outer surface has to behave properly in tension. For that reason the piece of wood used to make the bow is very carefully chosen from a specific part of a tree (I can't remember which one).
I also know that we brake rather a lot of them in testing. It was quite sickening to hear these several hundred year old weapons snap.
Posted 27/05/2009 - 00:02
Stihl's blowers looks quite sweet, read this:Looks like I'll have to get a better blower.
As Stihl's most powerful blower ever, the new BR 600 is ideally suited for the most rugged professional applications. Powered by a 4-bhp. and 64.8-cc displacement engine, the 20.9-pound unit delivers 201-mph air speed and 712-cfm air volume for one of the best blowing power-to-weight ratios in the industry. Its patented 4-MIX engine technology provides fast acceleration, added power, impressive torque and increased fuel efficiency. The BR 600 features a uniquely designed, ergonomic polymer frame with an adjustable harness system. Plus, the BR 600 is one of the cleanest-running machines in its class, according to data on the EPA's Web site.
You can't go wrong with that one ideally suited for the most rugged professional applications fits the bill right.
On the dutch forum there was someone wanting to blow it with a hair blower but that one blows hot air so not so good idea I believe.
Posted 27/05/2009 - 02:16
I need to find a good blower also....although the lst time I used a pressurized duster can...I blew dirt up inside my viewer..Now I need to find someone who can properly clean my camera
Posted 27/05/2009 - 10:36
Yew I believevery carefully chosen from a specific part of a tree (I can't remember which one).
the new BR 600
Can it suck as well?
the new BR 600
Posted 27/05/2009 - 11:27
Yew I believe
Not just Yew. Ash is quite popular as well.Yew I believe
pschlute wrote:
Very nice framing Father.
Thanks Other than a crop to straighten the image, (well, I was lying on my side on the ground to take it), that is as taken.
Wirral
Anyway, while I was waiting for her to arrive I got a couple of shots, ( not with my bow ).
I like this one.
C&C as always please.
[IMG]http://i75.photobucket.com/albums/i296/Father_Ted/PHOTOS/Longbow2.jpg[/IMG]
