K3 2Front e dial stopped working
Posted 07/01/2018 - 09:44
Try taking the battery out for 30 seconds and then replace
Chris
Posted 07/01/2018 - 09:49
Thanks for your prompt response. Just tried that but still the same.
Posted 07/01/2018 - 09:59
Other than that, is the camera working, i.e
is it auto focussing ok ?
does it take an image and is it correctly exposed ?
Chris
Posted 07/01/2018 - 10:00
Yeah everything else seems to working. I put in on auto aperture and it set the aperture as per and took photos no problems.
Posted 07/01/2018 - 10:34
Ok, try removing the lens,
Wipe the contacts on both the lens and the mount to make sure they are dry with a cloth, then put the lens back checking it clicks fully home
Check you are in the correct mode, does it work properly in say fully manual ( M ) ? can u adjust the shutter speed and aperture ?
Is there a card in the camera, or is the card door open, this has caught me out on one occasion
Chris
Posted 07/01/2018 - 10:35
Just investigating my issue and after pushing the on/off lever to DOF preview, the dial started working again.
Now I don’t know if that did the trick or if it’s because the camera has warmed up.
Will monitor the situation. I am off to update the firmware to the latest issue. I hadn’t done it because the camera was working OK.
Posted 07/01/2018 - 10:38
Thanks for your suggestions and once the camera has fully got back up to room temp I will clean the contacts. Hopefully it was just a glitch in the Matrix and it won’t happen again.
Mel
Mel
Posted 07/01/2018 - 10:41
Hi Mel,
No problem, pleased its either resolved itself of you've found the issue, make sure the battery is fully charged before starting the firmware update
Chris
Posted 07/01/2018 - 16:48
If it's that new and it does seem a problem then get it fixed under warranty.
Posted 08/01/2018 - 01:54
Firmware update is quite easy but, as said, do put a fully charged battery in. You won't need the power but it's good insurance.
9 years
First post. I have had my K3-II for just over five months, bought from new.
Today while out shooting (outside temp -2C) The front e dial has stopped working, can’t change aperture or move the tabs in the menu.
I have treated this camera very gently as it was a lot of money to me and it’s never been even been out in the rain and I always equalise the temp when returning home.
Have I pressed a button combination to disable the dial or is it broke.
Mel
