K20D + DA*300mm @ ISO 6400 - Does it cut the mustard?
Mannesty
Posted 15/07/2009 - 12:50 Link
At George's request to see ISO 6400 images from the K20D in daylight I took these images today from my bedroom windows, the main purpose being to include both highlights and shadows for comparison.
They've been processed through Noise Ninja and Picasa's 'I'm feeling lucky' colour/tone correction which has softened them a bit, normally the DA* 300mm will produce tack sharp images in these conditions but I think these are perfectly acceptable, though not stunning subjects.
All taken at f32, ISO 6400, Av mode, +0.7 EV comp.
Draw your own conclusions as to whether or not the K20D is good enough at high ISO.
Edited by Mannesty: 15/07/2009 - 13:01
Posted 15/07/2009 - 17:39 Link
Superb at iso6400 perfectly acceptable Peter
Mannesty
Posted 15/07/2009 - 18:04 Link
I think so too Martin. They might not stand printing at A3, but they are fine for my purposes.
Malo1961
Posted 15/07/2009 - 18:51 Link
Forget all the pictures but the last one. This one evidently shows.......................................................
There is nothing to show. So I think it is safe to say:
You have made your point, Peter. But of course, you already knew that.
Martin.
Best regards,
Martin.
George Lazarette
Posted 15/07/2009 - 19:33 Link
Thanks, Peter.
As Martin says, it is a bit hard to judge from the first ones, but the last certainly looks pretty good.
It's to counter the "received wisdom" about certain models and certain brands that I started my K20 vs D300 thread. From the look of this, I can only say that if the D300 is better, then it's probably not hugely better.
Posted 15/07/2009 - 19:39 Link
Care to show us some in low light at iso6400 please?
Anvh
Posted 15/07/2009 - 20:10 Link
But these are 800px image not really suited for print shall we say
Let's say we go for 6"x8" print on 300ppi that's 1795 x 2398 px or 4.3mp if we should do it probable.
Stefan
K10D, K5
AF-540FGZ
Mannesty
Posted 15/07/2009 - 20:33 Link
800 pixels on the longest side is the biggest I can show from Picasa.
You want more proof? OK.
Mannesty
Posted 15/07/2009 - 20:38 Link
George Lazarette wrote:
Thanks, Peter.
I would agree, but if you were to simply look at them as images (OK, the subject is rubbish but it's all I had time for today), and without knowing they were at ISO 6400, would you say they were noisy? I wouldn't.
I know these are not worthy of Pentax Gallery for instance but I'm trying to build a case for the K20D/K7 noise debate and show that it really isn't the huge problem that people (potential defectors) perceive.
George Lazarette
Posted 15/07/2009 - 20:49 Link
Mannesty wrote:
....if you were to simply look at them as images (OK, the subject is rubbish but it's all I had time for today), and without knowing they were at ISO 6400, would you say they were noisy? I wouldn't.
I would have thought they were taken between 400 and 800. Perfectly acceptable.
Mannesty
Posted 15/07/2009 - 21:02 Link
Thanks George, that's good enough for me. Let's hope a few others agree.
I'm just processing some low (very low) light shots. Same subjects, but it's now so dark that the street lights have come on and the AF system won't lock on without a bit (a lot) of encouragement.
I'll post them here in a bit, noisy or not.
Posted 15/07/2009 - 21:04 Link
Oh no dont mention a fault with pentax
Mannesty
Posted 15/07/2009 - 21:18 Link
Well it is almost totally dark and the DA*300mm is an f4 lens and it did eventually achieve focus lock when I chose the most contrasty part of the scene. I could have switched to the DA* 50-135mm ( f2.8 ) but I wanted to use the same hardware as previously. I don't want to invite criticism of it being an unfair test . I think probably only the military have cameras that work faultlessly in this light, could even be Pentax .
Edited by Mannesty: 15/07/2009 - 21:23
Malo1961
Posted 15/07/2009 - 21:20 Link
Why would you?? It's common knowledge that noise always is more pronounced when viewed on screen. Prints tend to be far more forgiving to alleged noise issues, then most people would expect. Thats one of the reasons the pixel peepers and measurebaters of this world are having such a good time. Like in the film days. If grain is a issue, work with it to your advantage. But then.....more and more people are starting of as a first timer in photography the digital way. Most of them take all that for granted not even knowing something like film even existed. I know......it's a bit overrated now, but ask me again in ten years. Sign of the Times........
Martin.
Best regards,
Martin.
Tooks
Posted 15/07/2009 - 21:26 Link
I took this one on a K20d at ISO3200. I'd been shooting stars the night before, and forgot to turn the ISO back down the next morning!
