K10D tilted viewfinder conundrum
J2R
Posted 25/09/2013 - 15:19 Link
I have a K10D (or rather, a Samsung GX-10, which for the purposes of this discussion is basically the same thing). I bought it 5 years ago and have hardly used it since I discovered (once the camera was out of warranty!) that the problem I was seeing in landscapes where the horizon was tipped down to the right by a couple of degrees was, in fact, a fault with the camera and not just me being inept. A bit of research has shown that this was in fact a fairly common problem with the K10D, and it seems to be caused by a misaligned mirror box.
Now, I can work around this by actually tilting the camera a little while shooting, if using the viewfinder; or by making sure the base of the camera is horizontal (the sensor seems to line up OK with the body - if I take a shot with a perfectly level camera, the horizon is fine). But this is a bit of a pain and I'd ideally like to do something about it. I've been quoted £96 plus VAT to address the problem. But I'm wondering whether I might just be better off ploughing that money into a replacement camera, maybe off eBay or somewhere, and seeing what I can get for my camera on eBay (with the fault acknowledged, of course!). I could probably pick up a K20D or GX-20 for under £200 and end up with what should, theoretically, be a slightly improved camera. Ideally I'd go for a K5 or K30 but they're a bit outside my budget at present.
What do others think? Is the £96 worth spending? Or is it a known problem which can be fixed at a lower cost, if so where?
Posted 25/09/2013 - 15:24 Link
I've just sold a pristine K20D that went for a low £185.00 and a K10D that went for £130.00, also pristine.
You could probably do your upgrade at a very low cost, less than a repair I would think.
J2R
Posted 25/09/2013 - 15:33 Link
Ha, don't I just know it! I tried to put in a higher bid on your camera with 10 seconds to go but neglected to click the Confirm button! I thought it would shoot up by £30-40 in the last few seconds but it didn't, so I was miffed to miss it (and you're probably miffed to sell it a low price).
I would presumably get far less than £130 for my camera, given its tilted viewfinder issue. I have to consider how much extra over the £96 I'd think it worth paying to get a camera which is apparently only a marginal improvement over the K10D. As the owner of both, would you consider the K20D to be a significant enough upgrade?
Algernon
Posted 25/09/2013 - 16:51 Link
Don't all cameras have tilted viewfinders
pgweber
Posted 25/09/2013 - 17:01 Link
My K10D has a "tilted viewfinder", borne out by one or two comments on my gallery pics. Either that or I have one leg shorter than the other!
I called in at Johnson's last year when I had a problem with one of my lenses and one of the technicians briefly checked out the K10D. He mentioned a masking plate in the viewfinder that was misaligned and the repair and service cost IIRC was circa £140. It was a recognised issue with some K10s apparently.
Pentax K5
Tamron 80-210mm & 28mm
Edited by pgweber: 25/09/2013 - 17:11
Posted 25/09/2013 - 17:44 Link
Some like the image quality of the K10D CCD sensor, but I prefer the K20D. I still use one for studio work.
J2R
Posted 25/09/2013 - 17:46 Link
Peter, how visible is the issue with your K10D? On mine it's very obvious on landscape photos featuring the sea. I haven't been able to measure it accurately but it's probably somewhere between 1 and 2 degrees.
pgweber
Posted 25/09/2013 - 18:19 Link
Others tend to notice it before I do, like on this shot:
https://www.pentaxuser.com/photo/user-5416/snowdon-spat-15377
Perhaps it's a bit like sensor stains - it's there if you look for it!
I continued to use the K10D until I got my K5 but was a bit put off picking it up again after the JPS tech said it was an issue with some units.
However I did take this shot earlier this year with the K10D and had it published in a railway magazine. The train was running at ~90mph at the time.
https://www.pentaxuser.com/photo/bittern-blowing-off-64445/large
I can't remember if I levelled it in Photoshop, which is ok for the occasional shot.
Pentax K5
Edited by pgweber: 25/09/2013 - 18:20
J2R
Posted 25/09/2013 - 18:59 Link
It is noticeable in the Snowdon shot but not gross. It helps if you avoid seascapes!
It's certainly possible to correct the problem in processing, with something like Photoshop or Lightroom, but it's a pain to have to do it each time, and it also introduces some degradation to the image (it's not possible to rotate by arbitrary amounts losslessly).
Nice photos, by the way.
J2R
Posted 25/09/2013 - 19:13 Link
I have to say I have no pressing requirement to upgrade, as I'm very happy indeed with the image quality from my GX-10 for landscapes, which is what I normally photograph. The tilt is the only problem (apart from a minor issue to do with exposure in older prime lenses, which I'll raise a separate post about).
