K10D Not Recognising Lens
Posted 21/06/2011 - 15:40 Link
A mate of mine recently bought a K10D that came with the kit lens and also the seller kindly threw in a SMC 70-200MM free of charge.
The lens worked fine for a few days but now when he attaches it to the camera it won't take a shot and the "F" has the two dashes after it like it would with a manual lens. It still works fine with the kit lens.
Any ideas?
fatspider
Posted 21/06/2011 - 15:49 Link
Has he tried cleaning the contacts?
My PPG link
My Flckr link
rlebleu
Posted 21/06/2011 - 15:50 Link
You did not give any detail about the SMC 70-200...
I suspect it is a manual focus lens, and does not have the proper connection to the camera to transfer lens information such as aperture etc. It will work fine, but you will have to use the camera in manual mode, as well as manual focus mode...
Dick
Posted 21/06/2011 - 15:51 Link
Sorry, I believe that it is this lens and does have auto focus etc
http://www.pentaxforums.com/lensreviews/showproduct.php?product=208&cat=44
Pentaxophile
Posted 21/06/2011 - 15:54 Link
Is the aperture ring set to 'A'?
Daniel Bridge
Posted 21/06/2011 - 15:55 Link
The aperture ring will have been moved from the 'A' position, and the menu option to allow the use of non-A lenses will not have been set. Get him to check the aperture ring.
Dan
Pentaxophile
Posted 21/06/2011 - 15:57 Link
Great minds and all that
Daniel Bridge
Posted 21/06/2011 - 15:58 Link
Fools seldom differ, and all that.
rlebleu
Posted 22/06/2011 - 01:34 Link
[quote:3496ace15f="Daydreamjay"]Sorry, I believe that it is this lens and does have auto focus etc
]http://www.pentaxforums.com/lensreviews/showproduct.php?product=208&cat=44[/quot...
Ah yes. Then I imagine the 'A' setting is necessary for the camera to detect and set the aperture as suggested by Pentaxophile...
My quick response was based on how many times the F-- shows up with my M 50mm f1.7...
Dick
Smeggypants
Posted 22/06/2011 - 06:21 Link
Dan
You forgot to mention that it might not be that and instead the contacts might need cleaning. Fatspider mentioned this in the 2nd post of the thread
Common problem.
pgweber
Posted 22/06/2011 - 09:34 Link
Dick
My manual focus Tamron lenses used with a PKA adaptor DO show indications of aperture or intermittently 'F--'.
A quick wiggle of the lens seems to restore the f-stop info display or as suggested above a proper wipe of the contacts.
Pentax K5
Tamron 80-210mm & 28mm
Edited by pgweber: 22/06/2011 - 09:35
Daniel Bridge
Posted 24/06/2011 - 18:32 Link
Dan
Common problem.
I didn't need to, Fatspider had already mentioned it. But I would bet on it being the aperture ring, rather than the contacts.
Peter's note about the Tamron AD2 lens giving F-- occasionally is something I've experienced too, but very rarely. Someone else's tamron had it much worse than mine, and it turned out to be the AD2 mount, rather than the lens (unsurprisingly).
Dan
