False colour from Kr
Posted 13/06/2011 - 17:39
Hi Old76,
What format is the k-r saving the pictures in?
Kind regards
Charlotte
Kind regards
Charlotte
Posted 13/06/2011 - 18:54
Sounds very like the issues I had with PEF files and Picasso.
The viewer in this instance was not interpreting the RAW data in the PEF correctly. The initial image is the embedded JPG. I worked around the problem by using a different viewer(IrfanView).
My Flickr account, constructive criticism welcome.
Posted 13/06/2011 - 19:00
It sound very similar to when I used the GX20 with Paint Shop Pro. What software are you using?
Posted 13/06/2011 - 23:26
I use Picasa also and I freaked when I saw this......I thought there was something wrong with my camera. Did some research and read that Picasa is just slow getting the RAW data from newer cameras interpreted and plan to have the K-r PEF updated soon. Sounds very like the issues I had with PEF files and Picasso.
I also used the same workaround with Irfanview. However, I took it a step further. I did some minor editing on the RAW image in Irfanview, then saved the file as a highest quality JPEG. Because I prefer the editing tools in Picasa, from there I opened the saved JPEG file in Picasa and processed to my likening. Worked perfectly with no apparent IQ degradation.
Posted 13/06/2011 - 23:33
Shoot in the highest quality JPEG or use DNG RAW files, and that should help.
Don't forget that cards should be formatted in the camwera they are to be used in.
Photoshop Elements is the program I would recommend to process your images.
Posted 14/06/2011 - 08:57
G'day Roland - if you like shooting RAW (and it appears you do), then move to the DNG format.
In my K-x manual, it's at Chapter 6 - 'Setting the file format', so yours may be somewhere nearby...
Posted 25/06/2011 - 21:39
Thanks, everyone for your comments and advice. I'm fairly new to this digital photography lark, and this was the first time I had ever used RAW, which I only tried because camera reviews suggest it captures all the information of the photographed image. I obviously have quite a lot to learn.
