K10D
Posted 09/11/2009 - 18:08
Welcome to the forum. I dont have a K10 but I would imagine this must be similar to the K20.
In the "set up" menu select "beep", then you will see "setting" and below that the tick boxes. Highlight "setting" and toggle using the rear four-way controller to show the loudspeaker symbol without a red line through it. Then press "menu" to return.
The beep on mine is incredibly quiet, much quieter than any of my other bodies but personally, I wouldn't want the camera to beep ever.
Posted 09/11/2009 - 18:11
thanks a lot gartmore but I have done that as they say but still nothing beeps
Posted 09/11/2009 - 18:13
I've had my K10D for nearly three years, never heard of this one, so congratulations on a very unusual problem!
Does everything else appear to work?
For example, the 'self-timer' beep option is ticked in the menu, and when you take a self-timer photo, the red LED (front and rear) flashes until it releases the shutter, but there's no beep to accompany the flashing?
As Gartmore says, it is pretty quiet. You get ten seconds of slow, and two seconds of fast beeping to listen out for with the 12s self timer, so perhaps worth making sure.
Posted 09/11/2009 - 18:19
Check your AF.S and AF.C settings. I might be wrong here so I am going out on a limb but I have the impression that if the setting is for AF.C that beep might not happen. You have to select AF.S to hear that beep sound when the focus is acquired.thanks a lot gartmore but I have done that as they say but still nothing beeps
Please correct me if I am wrong because I am not exactly certain of this. I have never handled a K10
Amin Photo Gallery
Posted 09/11/2009 - 18:39
thanks all for your replies.When I set the self timer Chris I get the flashing light but not a beep
Posted 10/11/2009 - 18:16
Hi and welcome to the forum
Posted 30/11/2009 - 03:45
Not an owner of a K10...but I would think that if you just bought it, you would be able to go back there and get the help???..YES???
Welcome to our forum!
Posted 01/12/2009 - 03:13
Hi and welcome!
Pentax K10D, *istDS
Pentax 18-55mm,50-200mm,Macro 100mm
Takumar-A 28-80mm, Sigma 170-500mm, Soligor Teleconverter x2
Finally!! Sigma 10-20mm
God, grant me the serenity to accept the things I cannot change, courage to change the things I can, and wisdom to know the difference.
https://pentaxphotogallery.com/maliskaoosthuizen
Posted 01/12/2009 - 17:13
Hello Eric and welcome to the forum.
The beep on my K10 is set as Ken described and it too is very quiet.
The older I get the faster I was.
Dave
K-3 II, K10D, DA16-85, DA*50-135, DA12-24, DA18-55, DA 50, Sigma EX DG 70mm Macro, Sigma 70-300mm, Sigma DG 120-400mm APO HSM.
Metz 58 AF-1.
My Flickr link
Dave
Metz 58 AF-1.
My Flickr link
This is my first post and it is a cry for help.I have recently purchased the above camera but no way can I get the "beep" to work. All the functions in the menu are ticked but to no avail.I have reset a number of times but still no joy. Help
