K-x NiMH battery problem
One question and then a thought or two
have you always given your location as Finland ?
Now for thought
1) could your batteries be cold ? They do not like being cold and will show depleted very quickly - but if left in a warm room will go back to a green indicator . I've not tried this with my K-x but certainly this happens with the Optio P70 .
2) the K-x manual does say use NiMH batteries or AA alkaline or AA Lithium - it emphasises on page 2 that no other re-chargeables other than NiMH should be used
3) Temperature range for the camera is 0C to 40C [ page 3]
Tavallisesti akut saa toimii, mutta kun ne on niin vanha se on periateseesti mahdollistä että ne on 'rikki' - ja ne camerat tarvii hyvin paljon virta.
Bret
And answers to other questions:
NiMH batteries were been on room temperature and they are brand new. I bought then at the end of October, but I used Litium batteries (K-x's inbox batteries) until last week.
I measured voltages now one day after charhing and voltages were:
1,375 V
1,374 V
1,377 V
1,376 V
Voltages seem to be OK, I think.
To morrow I'm going to put them into K-x. Let's see what happen now.
Jukka
flickr
"If your photographs aren't good enough, you're not close enough." - Robert Capa
Stuart..
On Pentax forum (US I belive) link
was
full Green lasts for about 1/3 (33%) usage (~400 shots)-
half Orange first shows when there is still about 2/3 (66%) capacity left (~800 shots left or lasts for ~600 shots) -
empty Red shows when there is about 1/6 (16.7%) capacity left (~200 shots)
And then total shots were 1200 taken with Sony Eneloops batteries.
Do you have shots counts with Lithium batteries?
Jukka
flickr
I now use only Sanyo Eneloop or Uniross Hybrio rechargable batteries and find the usage time quite good.
Graham
I tested these cell also with external load and voltages were (current about 330 mA): 1,272 V, 1,287 V, 1,269V and 1,267V.
I'm going to order Sony Eneloops and try with them. And for backups I try to find Lithium batteries. ReCykos I put to my flash. Let's see how Eneloops work.
Unfortunately I have to say that Pentax has done quite an unprofessional work with K-x power circuits. I have been working over 20 year on mobilephone R&D and this kind of problems are like beginners work.
Jukka
flickr
They will retain up to 80% charge if not used for 1 year and you should get a reasonable amount of use in camera.
Battery tests with La Crosse RS-900 intelligent Charger
Discharge current 500 mA
Voltage after . . . . . . 30min . 60min . 2h30min . 3h
La Crosse . . . . . . . . 1,14V . 1,13V . 1,11V . 1,10V
Fluke 97 multimeter . 1,26V . 1,25V . 1,24V . 1,22V
La Crosse's value was fron display (when discharged with 500mA
Fluke's value was measured from battery's terminals (when discharged with 500mA)
So, In my knowledge there aren't any problems with GP ReCyko in generally, but with K-x the situation might be different.
I got new Sony Eneloop batteries on Thursday and tried them. They seems not work better than ReCyko, but then I put Eneloops to charger and after 3h I tried again. I switch on the camera and battery indicator was green, but after couple of shots the indicator went orange. Not very promising.
On weekend I'm going to do same test with Eneloops and La Crosse as I did with ReCyko to see how Eneloops work under 500mA discharge.
Does anyone know what is K-x's low battery voltage limit with NiMH (limit when the camera shuts down)?
BW.
I wrote to Pentax Support to UK and they gave short answer to my ReCyko problem:
"Please try out the following batteries: Sanyo Eneloop. They are said to be the best for the DSRL's.
With kind regards,
Pawel Jedrzejczak
Pentax Digital Camera Support Team"
Jukka
flickr
After Christmas I can send you a "known good" set of eneloops for testing?
Bret
Äänekoski,
Finland
My first test with GP ReCyko wasen't success. ReCykos run out after few shots so I recgharge them (takes only 2h to) and tried again. Battery light was green at first, but after couple of shots indicator went orange and after a while to red (battery settings was NiMH + firmware 1.01).
Now I recharged them again with GP's charger and leave then in charger on 8 hours. Then I take ReCykos off and wait 2 h and measured the voltage, voltages was 1,4 V on all four batteries, so they should be fully charged. And that was on yesterday (12th of Dec.)
No, what should I do, put batteries back to the camera and turn power on right a way, or should I wait about 5 min (some proposal on the internet)and then turn on the camera?
Pentax K-x serial number 364...
Jukka
flickr
