K10D locked up
El Dingo
Posted 22/04/2011 - 15:19 Link
For the first time ever, my K10D has locked up. No button worked, even the on/off switch. Everything locked up until I removed the battery. (My GX10 has never locked up, btw).
Is this maybe more common than I think? Has anyone else suffered with this?
I'm on firmware v. 1.31. Card was in the camera, and all the images were intact (however, I'm only playing around with macro in the garden, so nothing important).
Hope this doesn't mean that the camera body is going to become unreliable...
El Dingo - K3-II and K10D
Posted 22/04/2011 - 15:24 Link
Removing and replacing the battery may be all that's needed, in which case no repair will be necessary. If it does prove to be a fault then JP Service Solutions are slow but good.
Blythman
Posted 22/04/2011 - 15:37 - Helpful Comment Link
Happened with my K-x in about October (2-3 months old at the time). Thankfully, I haven't been able to replicate it
Alan
El Dingo
Posted 22/04/2011 - 15:39 Link
Thanks John. Is this common? My computers are always doing it and I suppose that the K10D is really a small and very compact computer.
I wondered if other forum members have ever had this problem?
Posted 22/04/2011 - 15:45 - Helpful Comment Link
I've not experienced it yet with two *istDS, two K10D, two K20D and now two very new K-5.
However, others have and it is mentioned in the instruction manual, so it must be a recognised hazard. Just like a PC, a cold boot may be the answer.
Mike-P
Posted 22/04/2011 - 15:49 Link
Has happened to my K-7 and K-5.
Never the K10D though and I had that for two and a half years.
Don
Posted 22/04/2011 - 15:55 Link
my kr did it once.
I conclude it to be a user error.
I was shooting video with it, the first day, and by force of habit, I switched the camera off as I set it down.... it was still writing to the card and it locked up.
I take that incident and compare to what others have experienced (even on Canon's forums) and conclude that IF you or the cameras "Auto off" attempt to power the camera down WHILE it is still accessing the memory card, it will lock up.
That is my theory.
No actual evidence to back it up though, as I turned off my "Auto off" function and haven't made the mistake I made the first day since. Hasn't happened since either....
Blythman
Posted 22/04/2011 - 15:59 Link
With mine it was while I was taking shots on continuous
Alan
ChrisA
Posted 22/04/2011 - 19:50 Link
I've had it too, twice. Not for a while, though.
Battery out cured it both times.
doingthebobs
Posted 22/04/2011 - 21:33 Link
Happened to me a couple of times, Battery out sorted it. Both times I was up to something out of the ordinary, can't remember what though. I have had the K10 2 years now.
If you think about it, that would be brilliant for a PC, so I'm not worried.
Bob
Edited by doingthebobs: 22/04/2011 - 21:34
Oggy
Posted 22/04/2011 - 21:34 Link
Remember the "off switch" is not an off switch. It does not interrupt power from the battery, it simply tells the camera to ignore you until you turn it on again. This is why you have to take the batteries out.
It should also stop what Don did being a problem.
Don
Posted 22/04/2011 - 21:44 Link
unless the "Off" command (switch or "auto off" input) while writing to card cause a glitch in the firmware to lock up the camera....
but FWIW, that video file was corrupted...unreadable..
Edited by Don: 22/04/2011 - 21:46
Oggy
Posted 22/04/2011 - 21:50 Link
I would have thought (hoped) that either would have checked that there was nothing important going on before it was enacted.
Don
Posted 22/04/2011 - 21:55 Link
well, I'm not one for repeating my mistakes... but I tried it just now, and shutting it off while recording, did not lock up the camera, and the camera did play back the clip... so..... my hypothesis, based on my previous observation, may be incorrect.
Oggy
Posted 22/04/2011 - 23:53 Link
I think you are slightly braver than I Don. I thought about trying it then thought about the cost of a new card and didn't get round to it.
I would have thought this was one of the main reasons for having a "soft off".
