Jessops 360AFDP
Posted 20/05/2013 - 14:40
Jamie
I had exactly the same issue with the the Jessops 300AFDP, mine works fine with the k10 bus cannot cope on the K30.
I don't think it is a dud.
Paul
Paul
Digital
K-30, GX-10, DA 16-45, DA 18-55 and DAL 55 - 300
Film
ME Super, 2 x MX, SP 500 and SP F
and lense or 2
Film
and lense or 2
Posted 20/05/2013 - 16:28
Thanks Paul,
I've worked out how to set it to manual - S equals Manual (!) - and then I can set the iso, focal length, power and f stop. It works ok then. That will do for me - it'll make me slow down a bit when I use it - which is infrequently anyway.
Jamie
Posted 21/05/2013 - 09:11
Now I'm really confused. As above I managed to get the flash to work on my K30 in manual mode yesterday afternoon and it worked consistently. I tried it last night and again today and I cannot get it to fire in manual mode. If I put it in TTL mode it does fire - but does so erratically - every time a setting is changed a low power burst is set off. Once the camera is set it does work.
However when I try it on my son-in-laws K200 in TTL mode it works every time - without error. However I cannot get it to work on the K200 in manual mode.
Anyone any ideas?
Anyone any ideas?
Jamie
Posted 21/05/2013 - 09:33
Pentaxophile wrote:
I trust your shutter speed was set to 1/180 or lower? Other than that if your problems persist I'd be tempted to try another model. Legacy flashes with a manual setting are two a penny or you could try a yongnuo for more creative control.
Yes I had it set for lower than 1/180th. I appreciate that you can pick up cheap manual flashes - I just sold one on eBay for £0.99 . I trust your shutter speed was set to 1/180 or lower? Other than that if your problems persist I'd be tempted to try another model. Legacy flashes with a manual setting are two a penny or you could try a yongnuo for more creative control.
What I don't understand is what the difference is between the K30 and K200 flash control.
Jamie
Posted 23/05/2013 - 07:02
I can't remember but is the K200 TTL?
Posted 23/05/2013 - 08:35
Unfortunately my son-in-law never left me a manual for the K200 so I don't know -but that would answer the query. Though I thought someone said all digital Pentax were P-TTL.
Jamie
Posted 23/05/2013 - 08:40
No, it's P-TTL (as is the K30)I can't remember but is the K200 TTL?
Posted 22/02/2014 - 11:23
Sorry for resurrecting an old thread but after buying a Cobra D650 from another member here I thought I'd dig out this flash and see how they compared in manual mode. I eventually got a set of instructions for this flash - it appears to be a Tumax DPT386AFZ and the instructions do claim it is P-TTL. It's also appears to be sold as the Polaroid PL-144AZ.
I've managed to get it working in both manual mode and slave mode but not P-TTL the camera just fires the flash randomly - even without the shutter button being depressed. The strange thing is that in manual mode the camera shutter speed will go no higher than 1/90 with the flash mounted - no matter the other settings. With the Cobra D650 I can set the shutter to 1/160 and it works fine. With the Jessops there is obviously some interaction with the camera - it does have all 4 pins. It works fine in slave mode - firing off the on board flash ok.
Jamie
Posted 21/03/2014 - 19:14
Just another update on this for anyone with this flash or the listed badged ones. If you blank off the digital pin - that's the one on the foot towards the front of the flash then you can set the camera shutter speed to higher than 1/90.
Jamie
