HP print cartridges
Posted 17/12/2007 - 23:37
I know that using my multimeter set to continuity test mode, can reset the chip in an epson ink cartridge.....just by probing two of the electrical contacts on the cartridges chip.
Posted 17/12/2007 - 23:46
Thats interesting Don. How did you find that piece of information. I know that using my multimeter set to continuity test mode, can reset the chip in an epson ink cartridge.....just by probing two of the electrical contacts on the cartridges chip.
So it doesn't matter which 2 contacts : and keep trying until it works I guess is the procedure :
Camera:|K-7|
Posted 18/12/2007 - 00:01
I ripped apart an old printer, to see if the peizo electric printhead could be used to vaporize gasoline to replace the venturi in a minkuni carburator to improve throttle respons/fuel effiency on a motorcycle......
ran out of money/parts/fireextinguishers before I was able to prove my theory....
javascript:emoticon('')
Posted 18/12/2007 - 00:10
Hmmm Running a motorcycle on ink cartridges You maybe onto something there I ripped apart an old printer, to see if the peizo electric printhead could be used to vaporize gasoline to replace the venturi in a minkuni carburator to improve throttle respons/fuel effiency on a motorcycle......
Edit. So does that mean whatever coloured cartridge you are using that is the exhaust colour :
Camera:|K-7|
Posted 18/12/2007 - 06:26
Posted 18/12/2007 - 08:10
Well that blows Don's motorcycle theory out of the water
Anyway i tried Don's fix with the cartridges but to no avail. So if anyone has any other ideas i'm listening.
Camera:|K-7|
Posted 18/12/2007 - 08:28
Bin the lot. Why risk using degraded inks in your printer?
Posted 18/12/2007 - 08:40
I think you are right John. Bin the lot. Why risk using degraded inks in your printer?
As i said i wasn't aware ink had an expiry date.
I thought i had hit the mother load when i got 20 cartridges for nix. But it wasn't to be i guess
Camera:|K-7|
Posted 18/12/2007 - 15:09
would changing your computers date work? Fool the pc/printer that the inks were still usable?
Please call me aj,
Posted 18/12/2007 - 16:56
Good idea.would changing your computers date work? Fool the pc/printer that the inks were still usable?
Posted 18/12/2007 - 20:49
Thanks AJ your idea worked I backed the date up a month and now my PC recognises them. would changing your computers date work? Fool the pc/printer that the inks were still usable?
I was a little concerned the inks might be stale or some such thing. So i ran a few A4 print samples and the colours look fine, The inks were only just over thier use by date, if they had been a year or 2 i don't think i would have risked it.
But now my computer date is wrong. Oh well just have to live with it i guess. Thanks AJ and Don
Camera:|K-7|
Posted 18/12/2007 - 23:53
You can get your computer time clock updated automatically via a time server, this can be set to several times a day, so you can just change the date before printing and it will get changed back later.
or you can set up a script to change the date before printing and then change it back afterwards.
Please call me aj,
Posted 23/12/2007 - 23:30
You can find anything on the internet
I ran a search to see if i could over come the expirary date on these cartridges.
Well i found this http://www.alotofthings.com/supportforrefillers/expirationdatehp1011.htm Followed the instructions and i am back in business
Thanks AJ your idea also worked
Camera:|K-7|
Posted 24/12/2007 - 22:06
Well done, a brilliant idea. This is the greatest victory for the common over corporate greed that i have heard about this year.
Didn't Epson use to do that? ( I use compats anyways)
Sydney Australia
What happens to the ink after they have expired :
Is there a way around this or do i just put it down to experience and bin the lot.
Any help apprectiated.
