Eye piece blanking
Posted 29/03/2013 - 12:40
I don't use the Penjtax eyepiece as it doesn't fit the K-5. I've made one out of cardboard covered with black electrical tape and it works perfectly.
Light will enter the eyepiece if you're doing long exposure shots so it is important that you keep it covered.
DAvid
DAvid
Posted 29/03/2013 - 12:53
Likewise I don't use the Pentax gubbins - its too much of a pain to fit, then refit, then reset the dioptre setting which has invariably moved.
I use a bit of black plastic cut from an old tape box which just slides under the rubber surround
You can check out how much light gets in by taking two shots, one with one without blanking.
Incidentally if I'm taking a low level shot (not looking through the eyepiece) by estimating the shot I usually put my thumb over the eyepiece.
regards
Bernard
regards
Bernard
Posted 29/03/2013 - 12:54
DAvid
Are you sure? The same "Finder Cap" fits both my K-5 and K10D. And also my ME-Super and Super-A (and K-30, before I sold it). I don't use the Penjtax eyepiece as it doesn't fit the K-5.
DAvid
You have to remove the rubber eye piece, then slide in the cap in its place
Part number 31011. (Supplied as standard with the K-5 & K10D, but an optional extra on the K-30).
Posted 29/03/2013 - 12:57
Blu tack for me.
Posted 29/03/2013 - 13:54
Just cover the eyepiece with the hand, as the exposure is locked as soon as the shutter button is pressed.
Posted 29/03/2013 - 17:39
Roscoe wrote:
Does anyone use the Pentax Eyepiece cover when using a tripod?
Does extra light enter the camera and change the metering,or was this on 35mm cameras only
Yes it does. Does anyone use the Pentax Eyepiece cover when using a tripod?
Posted 29/03/2013 - 18:09
DrOrloff wrote:
Blu tack for me.
I would be worried that Blu Tac might damage the Anti Reflection coating on the eye peice
Blu tack for me.
K30, K-x, *ist DL. Pentax 60-250 F4, Sigma 18-125 & 70-300
Posted 29/03/2013 - 20:51
I never bother covering the eye piece TBH... With long exposures I metre, take the shot and if it needs adjustment I change the shutter to compensate and take the shot again...
Digital:
Flash:
Film:
Digital:
Flash:
Film:
Posted 29/03/2013 - 20:57
It's important to cover the eyepiece, the longer the exposure, the more important this gets. The issue is not so much whether the exposure will be out, it's more that you can end up with streaks on the image where light leakage over-exposes parts of it compared to other parts. There is nothing you can do to rectify this in PP.
Posted 29/03/2013 - 21:36
how much light can actually get past the raised mirror anyway?
Posted 29/03/2013 - 21:43
Small amounts, but when you're doing a long exposure this can make a big impact on the final image. A small amount of light falling on the sensor for 2 to 3 minutes for example can be clearly seen as streaks in the image.how much light can actually get past the raised mirror anyway?
Posted 29/03/2013 - 21:56
Exactly as David says. It's critical.
I chuck an old black t-shirt over. It's always in my camera bag.
Posted 30/03/2013 - 17:51
I presume if you use live view it will not make any difference
Pentax K5, Kx, DA15 ltd,18-135, 18-55, 50-200, M100 f4 macro, M135 f3.5 A28 F2.5
