DA*50-135 - another
Gamka
Link Posted 30/12/2013 - 15:32
Prompted by GTIS's thread I did a quick check on my lenses - the 50-135 has not been used for a while.
Guess what - it will not focus.
So, went through the various options, full battery, switching on/off, contacts, running it from one end to the other manually and with a fine screwdriver. NOTHING!
So, I tried my other lenses, DA*16-50, DA*300, FA24-90, FA20-30, DFA100 Macro. All work fine.
So, went to my old *istD and the batteries are dead, so back one step to my MZ-S. The DA*50-135 worked perfectly on that.
So, what is the focussing mechanism on the MZ-S? Is it using the drive screw or is it the SDM?
CIBarker
Link Posted 30/12/2013 - 15:37
Yes MZ-S is using screw drive, you'll notice it's no longer silent. I've had this lens with a lazy AF in SDM after prolonged non use, put it back on the DSLR you might find you've woken up the SDM
Gamka
Link Posted 30/12/2013 - 15:48
Tried that ... I'll give it another try later or tomorrow though.
SteveEveritt
Link Posted 30/12/2013 - 17:40
Mine wouldn't work on my K-7 but performed perfectly on my K-5iis maybe Pentax have upped the power on the later bodies?
My Flickr link
gtis
Link Posted 30/12/2013 - 19:18
Hi all
I have no other camera to try it on,pity it doesn't revert to screw drive when the SDM fails
I could live with that
cheers Neil
pentax k3 k5 super A
DA* 300 f4 DA* 50-135 f 2.8 smc DA* 16-50 f2.8 50mm f1.7 af 360 fgz pentax1.4xhd converter
Panasonic Dmc Fz200
digikid-tv
Link Posted 31/12/2013 - 16:41
It is possible to edit and rewrite the eprom in the lens to deactivate the SDM so that it is a screw drive only lens on any camera.
See: link
I recently did this to my DA* 16-50 (using a K10D).
John
