DA* 50-135
Posted 29/12/2013 - 15:09
Totally stopped?
Try manually focussing and turning it on/off several times and doing a manual focus to assist it when it should auto focus.
Posted 29/12/2013 - 15:36
Johnsons aside , you could try Asahi Photo or Harrow Technical. Alan Marlow is very good, but I don't think he services DA* lenses.
Before you send it off, try turning the screw drive, ideally by focusing on an old AF film body, if not turn the mechanism backwards and forwards with a small flat screwdriver. Then try again on your DSLR making sure that your battery is fully charged first.
Regards - Steve
Regards - Steve
Posted 29/12/2013 - 15:52
Hi Steve
Looked at Alan marlow's web site and he's not working until next year
Tried turning the screw drive to no success
cheers Neil
pentax k3
Panasonic Dmc Fz200
pentax k3
Panasonic Dmc Fz200
Posted 29/12/2013 - 15:53
Gamka wrote:
Totally stopped?
Will try this next
Totally stopped?
cheers Neil
pentax k3
Panasonic Dmc Fz200
pentax k3
Panasonic Dmc Fz200
Posted 30/12/2013 - 11:04
Hi all
Tried all the suggestions to no avail ,just waiting for some emails for quotes to get back to me
cheers Neil
pentax k3
Panasonic Dmc Fz200
pentax k3
Panasonic Dmc Fz200
Posted 30/12/2013 - 16:10
I usually use Alan but he was a bit reluctant to do my 50-135mm so I sent it to Johnsons. If I remember correctly the quote was approx £180 to fix the lens (new SDM motor) but if you join PU plus (£10) you get a 20% discount, so worth doing.
On the plus side I always found the 50-135mm very slow to focus but it's like a different lens with the new motor.
Posted 30/12/2013 - 19:15
Hi mike
Will phone Alan up and see what he says if he can't do it I will join PU plus and send it to them
I sent harrow technical a email but they are not at work until tomorrow I will see what they say
Many thanks to you all
cheers Neil
pentax k3
Panasonic Dmc Fz200
pentax k3
Panasonic Dmc Fz200
Posted 31/12/2013 - 10:26
Hi all
Just got a email from harrow technical they can't repair it
cheers Neil
pentax k3
Panasonic Dmc Fz200
pentax k3
Panasonic Dmc Fz200
Posted 31/12/2013 - 10:34
Harrow mainly do 35mm stuff. I'm afraid Johnson's is about it. I hope you don't need the lens for anything soon...
Posted 31/12/2013 - 10:37
Hi krisHarrow mainly do 35mm stuff. I'm afraid Johnson's is about it. I hope you don't need the lens for anything soon...
I will not want the lens soon probably at Whitby in april
cheers Neil
pentax k3
Panasonic Dmc Fz200
pentax k3
Panasonic Dmc Fz200
Posted 31/12/2013 - 10:40
You might get it back from Johnson's by then if you send it off now...
Posted 31/12/2013 - 11:49
I've had the same SDM trouble with my DA*50-135mm lens Neil. TWICE. Both times it went to Johnsons who are based in Newcastle; that's the Stoke on Trent one not the one up the road from me.
Both times Johnsons have repaired it quickly and efficiently. Staff there are very helpful.
The last time, this last autumn, it was away about two weeks and the £180 price quoted was reduced because I'm a Plus member of PUF. The return postage was also free.
Bottom line is you'll have it back working as good as new well before the next Goths Festival in Whitby.
Posted 31/12/2013 - 13:43
Hi DavidI've had the same SDM trouble with my DA*50-135mm lens Neil. TWICE. Both times it went to Johnsons who are based in Newcastle; that's the Stoke on Trent one not the one up the road from me.
Johnsons are not open until 6tth January will phone them up then post it the next day
cheers Neil
pentax k3
Panasonic Dmc Fz200
pentax k3
Panasonic Dmc Fz200
darfield sth yorks
My da* 50-135 as this morning decided not to auto focus so it will have to go for repair
Can anybody recommend someone ,I know of johnsons but is there anybody else
pentax k3
Panasonic Dmc Fz200
