Changing exposure
autumnlight
Posted 23/05/2015 - 14:24 Link
Hi i've been trying to change exposure time on the Pentax K5, if i use TAv, ISO is automatic, if i use Av, exposure is automatic and if i use Tv, f setting is automatic, i don't know if i have changed something in the camera at some point, i'm sure i could change the exposure time when in Av ... but then i'm old, i would really like to change all settings to suit conditions and try some more long exposures in the day, thank you in advance if you can help and sorry for being dopey
Posted 23/05/2015 - 14:33 - Helpful Comment Link
If you use Av, you set the aperture and the camera sets the shutter speed to match. To achieve a long exposure all you need to do is set a small (large number such as f/16) aperture and you'll see what setting the camera will use in the viewfinder display.
Alternatively, use manual and set what you want, but you will have to watch the exposure display to make sure the exposure is correct. Just centre the readout by changing aperture, shutter speed or both.
autumnlight
Posted 23/05/2015 - 15:01 Link
Thanks John for your help
sterretje
Posted 23/05/2015 - 16:17 - Helpful Comment Link
The exposure time might not change if you use auto-iso because you leave it up to the camera to decide what to change and by how much.
McGregNi
Posted 23/05/2015 - 21:41 - Helpful Comment Link
When working in an 'automatic exposure' mode such as Av, TV, Tav, Sv, the process to adjust exposure is 'exposure compensation', which forces the camera to change the exposure value (ev) by adjusting the variable parameter and while holding the 'priority' parameter ....eg in TV mode then 'time value' is the priority parameter, and aperture would be varied to force the exposure change.
Maria, you said you wanted to change the 'exposure time' ,so I'm guessing you wanted to have a slower shutter speed for a movement effect. I suppose if you needed to do this but wanted an automatic exposure, then TV is the mode to choose. As you lengthen the time value then to compensate the aperture would get smaller and smaller, keeping the brightness the same.
I agree with the others here who have referred to manual as the most versatile mode, but as said you need to keep a close eye on the exposure variation scale along the bottom of the viewfinder to be sure you don't get too far away from your intended brightness.
autumnlight
Posted 23/05/2015 - 22:59 - Helpful Comment Link
Thanks Nigel, i understand this but i think what i was hoping for was a way of adjusting these setting myself without them going on auto, i was just hoping for the best of both worlds, i'll try manual again and hope the exposure variation will be kind to me, many thanks
davidstorm
Posted 23/05/2015 - 23:11 - Helpful Comment Link
Hi Maria
My suggestion would be to set the camera to AV mode, get the aperture set as you want it and do a test shot to judge where the exposure / shutter speed needs to be. Once you've done this to give a guideline, it's easy to switch the camera to manual and tweak it from there.
I use this method a lot, but also use the exposure compensation mentioned by Nigel, almost always I will be in AV mode when doing this.
I've put a very simple little shot on the Gallery today that uses the exposure compensation in AV mode, this one was under-exposed by just over 2 stops to make the background dark.
Best wishes
wvbarnes
Posted 24/05/2015 - 10:05 - Helpful Comment Link
Hi Maria,
I use TAV mode but restrict the allowed ISO range to suit, easily done from the info screen. I consider what i'm doing and set shutter and aperture accordingly. I find that a nice compromise between semi auto and full manual which of course you can also use and use the plus/minus meter from the viewfinder and top LCD display
redbusa99
Posted 24/05/2015 - 10:19 - Helpful Comment Link
Hi Maria, in full manual you should be able to set exactly what you want i.e. narrow aperture , slow shutter, with nothing changing but depending on what you are trying to achieve with the slow shutter speed you may also need to attach an ND filter to the lens to get the speed slow enough
odd lens or 2
Edited by redbusa99: 24/05/2015 - 10:19
richandfleur
Posted 24/05/2015 - 10:56 - Helpful Comment Link
Can't you use the exposure adjustment to influence Av mode for example?
I use this when then metering is not correct for my subject. Such as a bird against a bright sky, where the metering will be based on the big bright area and not the bird.
bforbes
Posted 24/05/2015 - 11:14 - Helpful Comment Link
Maria, maybe you will have to resort to ND filters if you require very long exposures.
autumnlight
Posted 24/05/2015 - 18:06 Link
Thank you everyone for your great tips and advise, i've been trying to capture the small birds in flight or as i have put on the gallery today a young bird that is shaking it's wings in anticipation for some food, the trouble i have found is that on Tav the ISO is higher than i would want sometimes as it is on auto, this worked out at 500 and therefore the bird isn't as sharp as it should be, i'm going to get more practise in using the different settings you have all kindly shared so thank you again
richandfleur
Posted 25/05/2015 - 11:26 Link
You can totally limit your ISO to a fixed value or a min and max band.
autumnlight
Posted 25/05/2015 - 15:28 Link
Do you mean you can have a fixed ISO on Tav or in manual? i've tried everything
richandfleur
Posted 25/05/2015 - 15:40 - Helpful Comment Link
Others will comment, but looking back up I see you have a k-5 camera. Something looks to have changed between that series and the k-30 that I have.
In my k-30 I can select a fixed ISO value in all the modes you list, or I can select a band from which the camera is allowed to pick from. This came up recently but it appears that behaviour is different n the more modern camera bodies.
Apologies for not checking the model earlier. In tapping this reply out on a cell phone. Bottom line is I can, but I'm not sure about your camera sorry.
