Cable switches or remotes
Posted 26/03/2010 - 20:31
I bought a cable remote about 9 months ago off flea-bay. It has the letters JJC and MR series on the top, and has now stopped working, so I would also like to hear of any recommendations.
Posted 26/03/2010 - 22:35
I have a remote, by Pentax and love it. Gives me the ability to move around without worry of wire. The only drawback - it must be pointed at the camera with no obstruction. I also have a Pentax cable switch, which is handy if I'm not dashing around.
There is a remote available that uses radio signals instead of the Pentax IR. This would be the best bet, but I'm sure it is pricey! I believe the name is Pocket Wizard. I shall see what I can find out.
Regards,
Stephen
Regards,
Stephen
I gladly welcome C & C's. Being foggy minded they really help me learn.
Posted 27/03/2010 - 08:35
I use a Wired and Wireless twin 1 R3-UT which i bought to replace my Pentax digi cable release. It works on any make of camera, Wireless range is 50 m on Pentax and Nikon and 25 m on Canon but it works as a normal cable release too. I still have my Pentax I R remote which i keep in my memory card wallet for travelling light.
Regards - Pete.
Regards - Pete.
Posted 27/03/2010 - 08:42
I use the Pentax IR remote for tripod work. I have attached it to a lanyard so I can wear it round my neck. Saves dropping it and helps you work out which way round it is in the dark!
I find it much less hassle than a wired remote.
Nigel
Nigel
Posted 27/03/2010 - 13:29
Have a look at This thread
At that price you can buy one withought worrying how you get on with it and just try it out.
Works very well and with your k-7 can use both behind and infront of the camera.
Pentax K-5
DA 18-55mm AL WR DAL 50-200mm Tamron 70-300mm, Auto Chinon 28mm 2.8. sigma 30mm 1.4 DC
Metz 48 af-1
Metz 48 af-1
Posted 27/03/2010 - 14:10
My Pentax Remote Control F is now 15 years old and still running on the original battery. TBH I would have thought I would have lost it by now.
Posted 27/03/2010 - 14:18
That Remote control F is so tiny I'm scared of loosing it , sadly I can't see how to get a lanyard onto it to stop me putting it down and not finding it again .
let the education continue
Posted 27/03/2010 - 15:46
I used a lanyard from (I think) a USB drive. It has a thin loop attached by a spring clip to a thicker neck strap. After taking the remote apart, I made two grooves either side of one of the corner screw posts and then put it back together with the loop round the screw post and out through the grooves.
Posted 27/03/2010 - 15:50
Pentax used to supply a strap with two little pockets on it - one for the remote and one for the eyepiece cover. Sadly they no longer do that, and I have now switched to a new, more comfortable strap. Kata make a strap with two similar pockets. very useful, but not the strap I chose .
My remote now lives in my SD card case, a natty little case I acquired when I bought a card a while ago.
Posted 27/03/2010 - 15:51
I ain't that clever
Had been thinking of attaching a small ring with super glue or some such and then attaching a lanyard .
Still thinking and cogitating
Posted 27/03/2010 - 16:18
Much better
Thinking of another source too - must go and check that one
21 years
Birmingham
To avoid the problem of a wire that can be danmaged I am thinking of getting a remote. I assume many of you use a remote - what is your experience with one and are they effective?
Any advice on this would be welcome.:
John
My Kit
K5 & 18-55 Kit lens, K7, Pentax 18-250mm lens, Sigma 10-20mm lens, Sigma 105mm Macro lens, Pentax 50mm 1.7 lens, Cokin P Series Filters
