Cable switches or remotes
Aiki
Posted 27/03/2010 - 16:52 Link
Using Pentax remote F. (remote E being same)
It is working well, no probem.
Just I cant understand why isnt there any loop to put a ribbon through it and have it round my neck.
When I want to change the settings, I put it away into pocket...and then I have to search for it from there again and check if it is in right direction in my hand. uncomfortable.
The button could be bit larger too - in the case I have got gloves in my hands. Winter ...you know is not too warm.
Aiki
Pentax K20D; SMC DA 18-55mm II kit; Sigma AF 70-300/4-5.6 APO DG MACRO
GIMP Flickr
techno-terminator
Posted 27/03/2010 - 16:55 Link
Yeah - that's what I'm worried about - it's so darn small
let the education continue
helios
Posted 28/03/2010 - 10:25 Link
I use a cheapo wireless remote that I bought on eBay 2 or 3 years ago. It works by radio signals so is not restricted to line of sight like the IR remotes. Similar probably more modern versions are available on eBay for about £15. link
Archie
Archie
Smeggypants
Posted 29/03/2010 - 05:23 Link
I bought a cheap cable remote off E-bay. After 2 or 3 weeks it packed up. I got a Stanley knife, cut off the moldings from the mini jack plug and re soldered the broken wires back. wrapped in loads of black insulting tape. works fine now
PeteL
Posted 29/03/2010 - 17:18 Link
technoidiot wrote:
That Remote control F is so tiny I'm scared of loosing it , sadly I can't see how to get a lanyard onto it to stop me putting it down and not finding it again .
I have pieces of Dayglo attached to my F which helps.
Regards - Pete.
fatspider
Posted 29/03/2010 - 17:25 Link
Gwyn wrote:
Pentax used to supply a strap with two little pockets on it - one for the remote and one for the eyepiece cover. Sadly they no longer do that, and I have now switched to a new, more comfortable strap. Kata make a strap with two similar pockets. very useful, but not the strap I chose .
My remote now lives in my SD card case, a natty little case I acquired when I bought a card a while ago.
And the pockets were so tiny it was a struggke to get anything in or out of them
As for the wireless remote F, I was always afraid of losing it out of my camera bag, now its safely tucked away in the grip And like Ken, I've had mine quite a few years (10+) and still on the original battery.
My PPG link
My Flckr link
Gwyn
Posted 29/03/2010 - 21:32 Link
No problem getting things in - and I'd squeeze them out like from a tube of toothpaste . Maybe smaller fingers helped too.
Kenty
Posted 30/03/2010 - 11:43 Link
Thanks for all your comments - so much food for thought!!
I'll have to re-read the posts and the links so I can finally decide which remote to go for. I'll give up on cable switches as I've somehow broken 2 over the last 3-4 years!!
John
On a dark desert highway, cool Pentax K5 in my hand.
My Kit
K5 & 18-55 Kit lens, K7, Pentax 18-250mm lens, Sigma 10-20mm lens, Sigma 105mm Macro lens, Pentax 50mm 1.7 lens, Cokin P Series Filters
