Blue tinge?
Posted 04/03/2010 - 17:10
Yep, I can see it too so it isn't just your monitor!
I'm not really sure what's causing it - I have had similar effects caused by haze, and also when there's a lot of snow about which upset the auto white balance. I would suggest that it's a white balance problem assuming that the weather was clear when you took the photo.
Posted 04/03/2010 - 17:15
Last week I assembled all my lenses and in turn, took a picture of a dull white evening sky (minimal discernible cloud to be seen). I shot RAW images in each case.
My Pentax 16-45 & 18-55 Mk1, Samsung 50-200 and Rikenon 50mm f2 all gave a blue cast on the image.
My Tamron 28mm & 80-210mm gave a grey/white appearance to the sky.
Having reviewed other photographs taken with my 18-55, I concluded that it was not unusual to see somewhat of a blue cast.
The differentiation between Pentax/Samsung, Ricoh and Tamron might be as a result of different lens coatings applied.
Also consider which type of White Balance correction was applied.
Pentax K5
Tamron 80-210mm & 28mm
Pentax K5
Posted 04/03/2010 - 17:54
Like other said, white balance seems a likely suspect.
Were there any filters on the lens?
Tim
Posted 04/03/2010 - 19:03
Thanks all for your interest and replies.
Howard
Pleased it's not my monitor nor my eyes! The weather was clear and sunny.Yep, I can see it too so it isn't just your monitor!
None at all.Like other said, white balance seems a likely suspect.
pink wrote:
I would say WB was it on auto??
camera setting would help what program was it set to ??
James
K10D set to AWB, Av, f16 and ISO400 and JPG. It's been cropped a bit and sharpened but not excessively. I've got a raw file but my trial version of Silkypix has expired so can't try things out. Strangely I've not noticed it before.I would say WB was it on auto??
James
Howard
Cymru Am Byth
Posted 04/03/2010 - 19:46
What blue haze? I just want to be there. Whitsun still seems a long way off...
Oh yes, it is a bit blue. You can sort it out in Photoshop, I expect.
That snow, the Carneddau, the Straits...
Regards,
Regards,
Best wishes,
Robert Adams
Ernst Hass
Robert Adams
Ernst Hass
Posted 04/03/2010 - 19:56
HowardJ wrote:
I took this on Tuesday morning at approx 10:30 in good light. On my monitor and to my eyes there is a blue cast to it. Does anybody have any idea what mmay have caused it? Taken with a 18-55 Mk1. Is it the lens, is it the light or as is probably the case is it me? I've tried to get rid of it but to no avail.
[IMG]http://i83.photobucket.com/albums/j311/Tinywales/NorthWales/menaI_bridge_1.jpg[/IMG]
Any advice greatfully received and please feel free to experiment if you so wish.
Howard
Not sure about digital stuff but if you see this effect on film it is due to UV light. Try a UV filter and see what difference it makes.I took this on Tuesday morning at approx 10:30 in good light. On my monitor and to my eyes there is a blue cast to it. Does anybody have any idea what mmay have caused it? Taken with a 18-55 Mk1. Is it the lens, is it the light or as is probably the case is it me? I've tried to get rid of it but to no avail.
Howard
Steven
Posted 04/03/2010 - 20:04
Indeed, you can just use the white clouds to set the correct white balance it becomes slightly less blue then.
Posted 05/03/2010 - 11:56
There is a thread in the "Lenses For Pentax Cameras" forum which is currently discussing the effects of coatings.
https://www.pentaxuser.com/forum/topic/a-s-vs--da-s-18375
My experiments with lenses from different manufacturers were done using RAW files so no WB issues, where Pentax/Samsung & Ricoh looked blueish, Tamrom looked neutral.
Regards,
Regards,
Pentax K5
Pentax K5
Posted 05/03/2010 - 14:33
It looks blue to me on both my laptop (IBMT61) and PC monitor.
Colin
Edmund Burke (1729 – 1797)
20 years
Cheshire
Howard
