A's vs. DA's
Dr. Mhuni
Posted 03/03/2010 - 13:24 Link
I have recently acquired a Pentax A50 f2.8 Macro lens and have been interested to note its colour rendition qualities in comparison to my Pentax DA zooms. I was curious to know what other peoples' impressions of A lenses vs. more modern ones.
I find the DAs are much bolder in their rendering - the A50 more subtle. See the following images of the same dog taken around the same time of day (but not the same day) at the same place.
DA55-300
A50
As you can see the A50 has produced a much less saturated image. Not sure yet whether this is a good or bad (or superfluous - it is easy to adjust the colours in pp-ing) thing. I guess there will be times when I want the more subtle approach of the A50. In any case, it's other qualities are undisputed - the sharpness is outstanding. Here, the first image received much more sharpening in pp. It also seems to have some of the fabled 3D characteristics of the Ltds.
As another example of the colour rendition, the following was also taken with the A50:
With a DA lens I would have expected the colours on the front of the bus to be much bolder.
Mhuni
500px
Anvh
Posted 03/03/2010 - 13:33 Link
It also depends on the lens so far as I know, it's not really a matter of A vs DA.
I must say that I like the slightly bolder colour of the DA but it's a matter of what kind of photo you shoot if the one is better then another.
Stefan
K10D, K5
AF-540FGZ
thoughton
Posted 03/03/2010 - 13:45 Link
I can't comment as I no longer own any DA lenses but I like the pics!
Tim
Mongoose
Posted 03/03/2010 - 13:52 Link
I too have found that DA series lenses tend (general rule, so there will probably be exceptions!) to be more contrasty and give more saturated colour rendition than older (eg A series) glass.
I prefer the rendition of the older lenses personally, as I find it more flexible. I believe the newer lenses are intended to give a more "print ready" result, although that is just my assumption rather than based on any real evidence.
but it does help
Dr. Mhuni
Posted 03/03/2010 - 14:16 Link
Thanks Tim. But is your lack of a DA a preference or an accident.
Mongoose - I haven't really had the lens for long enough to reach a conclusion yet but I was wondering, like you, if the A50 might produce images that were more flexible. Colour wise that is - optically the A50 shoots all my DA's out of the water, even the 12-24 which is remarkably sharp for a zoom.
Mhuni
500px
Edited by Dr. Mhuni: 03/03/2010 - 14:17
Dangermouse
Posted 03/03/2010 - 14:35 Link
I do think the K series glass tends to produce cooler tones than the later series, but I don't really see it as a criticism, more a feature of the glass. I've been told that the coatings on older glass "aren't designed for digital" but this really doesn't seem to bother my K-m.
What amazes me is how good the various 50mm and 55mm lenses still are, considering that they were sold as the standard lens with every 35mm SLR Pentax made for a couple of decades. While the 18-55mm DA L is one of the finest kit zooms out there it just doesn't compare to the old M or A 50mm.
thoughton
Posted 03/03/2010 - 15:41 Link
Mostly coincidence, I don't have anything against DA lenses, but also due to budget e.g. Sigma 10-20 instead of 12-24, Tamron 17-50 instead of 16-50, Tamron 90 instead of DFA100, Tamron 70-300 instead of 55-300 etc. Photography is just a hobby, second best at half the price is often good enough for me. An exception might be the 50-135, I probably would have got that by now if SDM was more reliable.
Tim
Edited by thoughton: 03/03/2010 - 15:46
dynamosh
Posted 03/03/2010 - 15:43 Link
Hi Mhuni,
Great to see that the 50mm Macro is getting some use! I love the buses pic in particular, to my mind the colour rendering with the K, M and A series lenses is more natural than the newer lenses - ie. it looks more 'real'.
You certainly seem to being doing more justice to that lens than I ever did!
Dr. Mhuni
Posted 04/03/2010 - 03:29 Link
Cheers, Mike. The lens has found a happy home - I love it!
Interesting - I think I would have gone down your route too if I hadn't got a load of DA zooms in the halcyon days of December 2008 when there was a £50 rebate offer on many lenses and the old (old) prices still applied.
Very nearly got a DA50-135 too before the last price rise when I was in the UK last summer, but in the end decided it was too bulky for me to take with all my other equipment to Sri Lanka (was moving from Ethiopia then). It was probably the right decision at the time, even though I could have got it with VAT refunded for under £500. Am still hankering after it, but like you am a bit wary of the SDM on that lens (others seem okay) and - now - the price. Have you considered the Sigma 50-150? I know the DA50-135 is viewed as a peerless zoom by many, but I've read comments in various places (including those of Mike-P here) which indicate it is of comparable quality image wise (though apparently it tails off from ca.135-50, which the DA doesn't have in any case). It's also significantly cheaper.
Mhuni
500px
thoughton
Posted 04/03/2010 - 08:50 Link
Funnily enough I was drooling over the 50-150 on SRS's site last night £500 and change is certainly a lot more palatable! The size of the things worry me slightly too, part of me thinks if I'm going for such a large lens perhaps I should get a 70-200 2.8 instead. I think I would give up the 20mm at the short end for 65mm on the long end if the IQ was similar. Lots more research required
Tim
Edited by thoughton: 04/03/2010 - 08:54
Dr. Mhuni
Posted 04/03/2010 - 09:01 Link
Have been going through a similar thought process myself, but am increasingly concluding that I'd rather have a shorter high quality 2.8 and a teleconvertor. A big factor in my reasoning is the fact that the 70-200's constitute a significant (further) step up in size.
Mhuni
500px
Anvh
Posted 04/03/2010 - 13:45 Link
I bought my DA*50-135 for the same price the Sigma is now just a year ago so for me it was an easy decision.
It depends on what you want to do if the 50-135 or the 70-200 is better.
For portrait the 50-135 is just perfect but for sports I would go for the 70-200 just that extra reach makes it more useful there. I also consider the 50-135 a better walk about lens, smaller size weather-sealed and wider angle makes it handy.
Stefan
K10D, K5
AF-540FGZ
robbie_d
Posted 04/03/2010 - 13:52 Link
I find that my A 28mm f2.8 renders colours more "naturally" than my A 50mm f1.7, which is more colour saturated. My DA Fisheye I find to be slightly more saturated than the A 50mm f1.7.
Apparently.
Mannesty
Posted 04/03/2010 - 18:12 Link
The A series lenses lack the 'anti-ghosting' treament that is applied to DA lenses and some FA lenses. I think this may be the reason for the less saturated look in the images taken with older lenses.
It's also possible that the formula of the SMC coating may have changed slightly over the years as will the glass used to make them.
I'd label it as a characteristic rather than a problem. Saturation can always be increased in PP.
Dr. Mhuni
Posted 05/03/2010 - 10:47 Link
The coatings explanation would make sense, Peter. And you're right it is a characteristic not a problem. If anything I'd say the A's gave greater scope in pp-ing (and may well be more natural to begin with).
Mhuni
500px
