AF discrepancies at lower zoom levels
  • Topic Locked - You will not be able to post to this topic. Repeated subject
surfseen
Posted 31/07/2011 - 00:53 Link
I have been testing my Kr for bf and ff. I have found that at the upper zoom of the Pentax 55-300, 37-80, and 18-55, the AF is spot on. But at the bottom zoom level the focal point seem to be a little forward. Is an inherent problem with zoom lenses or is an issue with the KR only.
Also more difficult to focus correctly on an objects at the same distance with the lower zoom, than with the upper zoom. Is this natural, as you may have to get a lot closer with the lower zoom, to AF properly.
Probably photography 101, but it makes sense that at lower zooms, the same object loses its command of the focal point in favour of the closer surroundings, around the object. To put it another way, if you wish to use the single point AF, then you would have to get closer to effectively AF correctly on a single object.
Am I right, or is it my camera.
KR, Pentax 55-300 DAL, Pentax DA 17-55, Pentax 35-80, Generic grip, Generic remote, Nissin Flash. HISTORY - MZ 50, MZ 60, *istDS, KM, K20D, Nikon F60, Nikon F90. Large assortment of Point and shoot film and Digital, Sigma 70-300 APO DG, Samyang 500mm mirror lens, Sigma lenses of all assortments. K20D now sold. Sad to see it go, but makes room for an eventual upgrade to the K5 or the K4?
Posted 31/07/2011 - 08:37 Link
This is really repeating your other thread, so please refer to that. Otherwise we'll have two sets of respones.
See: https://www.pentaxuser.com/forum/topic/kr---af-fine-adjustment-29444
Edited by johnriley: 31/07/2011 - 10:12
