Youngnuo YN560TX
Posted 13/10/2014 - 07:36
I have had one for a few weeks, and it works well on my K3, with 2 yongnuo flashes, even works with my compacts.
Sony A6000 plus a bunch of lenses
Sony A7ii plus loads of glass
Fuji X20
Fuji X20
Posted 13/10/2014 - 10:09
Brilliant news thanks for the reply..
Stuart..
Stuart..
Posted 13/10/2014 - 10:46
No problem
I'm very new to manual flash, and was astounded the Yonguo can fire while the K3 is in high fps mode, great little units.
Fuji X20
Fuji X20
Posted 13/10/2014 - 11:03
I just have the Yongnuo 560 II, and it works fine on, or off, body (a K20 in my case), and the same with a compact as well.
Reckon the build quality is rather good as well.
Geoff
Geoff
Posted 13/10/2014 - 12:25
I have the yn560iii flash units. Is there a flash that is better value for money than these ? I wanted the unit for when I put the flash inside an octobox. It really is a pain to change the settings. For 25-30 quid. This will be a dream come true..
Stuart..
Stuart..
Posted 13/10/2014 - 12:27
You cant turn the power up and down on the YN560II though Jeff. Makes a big difference on a multiple off camera set up.
Stuart..
Stuart..
Posted 13/10/2014 - 15:04
stub wrote:
But joking apart, my YN560II has a range of power settings accessed with the 4-way control button set.
Oh gosh, mine has adjustable output. Do you think I should send it back?You cant turn the power up and down on the YN560II though Jeff.
X-5
istDS
K2000
P50.
X-5
istDS
K2000
P50.
Posted 13/10/2014 - 15:48
I was referring to the fact that you cant remotely adjust power settings using the YN560TX controller. On the MKII version of the flashgun.
Stuart..
Stuart..
Manchester
Stuart..
