Wireless flash question
Posted 20/02/2011 - 22:31
I have several flash units that do that, to conserve battery !
I suspect it does it on the camera too !? right ??
You need a flash unit that stays on, possibly with a different position on the on switch. My 360af stays on in wireless mode, as does my Nikon SB.
Hope this helps
Hope this helps
K-7 | K10 | DA 18-135 | DA 18-250 | DA 55-300 | DFA 100 |
Posted 20/02/2011 - 22:38
Mannesty wrote:
cardiff_gareth wrote:
Jon
It might help if you told us the exact model numbers involved.
Good point, Pete The flash is a Centon FH-95 and the trigger unit is a Neewer CT-04.It might help if you told us the exact model numbers involved.
All I can say is so far from playing with wireless triggers with a Metz 48-af1 is that this gun doesn't do that or maybe u have been lucky?!!!
At the risk of seeming 'thick', Gareth, are you saying that you have or have not experienced the same problem with the 48 AF-1?All I can say is so far from playing with wireless triggers with a Metz 48-af1 is that this gun doesn't do that or maybe u have been lucky?!!!
Jon
Wiltshire,
U.K.
If it is the flash, has anyone successfully managed a modification that will prevent this happening?
Jon
