Wide angle prime k mount for Pentax MX?
Posted 17/01/2012 - 21:15
I would be looking at reviews and sample images from the Pentax K or M 28/3.5, K or M 20/4 and K 24/2.8.
Another contender would be the Sigma SuperwideII which is sharper than the K 24/2.8 but not as 'proper' looking on the MX nor quite as good colour/contrast perhaps... (you can tweak those in PP though...)
Posted 17/01/2012 - 21:23
The Sigma mini-wide is 28mm, and reputedly very sharp.
The Sigma super-wide is 24mm and is excellent, I have the AF version & had the MF version. Focus is the same direction as Pentax lenses. The AF version is better built but larger. I have yet to use it on my MX, but I certainly plan to.
If you're going for a Pentax lens the K or M 28mm f/3.5 versions are optically similar but both very, very sharp (at least on digital), and made for landscapes. I have both but have not had any opportunity yet to compare them. Anything wider than 28mm in a genuine Pentax lens will not be cheap.
Posted 17/01/2012 - 21:29
Vivitar 19mm 3.8 will be UW on film...
Digital:
Flash:
Film:
Digital:
Flash:
Film:
Posted 17/01/2012 - 21:32
The K lens is a different formula and supposedly better but both are very good lenses. If you have the choice, get the K (the K versions are usually slightly better than their 'miniturised' M counterparts).
Posted 18/01/2012 - 08:57
Another vote for the Sigma SuperwideII. I also have the Pentax M 28 f3.5 which is very good too. Should be able to get either on ebay for around £50 ...or less if you're lucky.
.........all the gear, no idea!
Me super, MX, LX, K5,DA 18-55WR, DA 17-70, DA 55-300, DA40 Ltd, FA50 1.4, Samsung D-Xenon 12-24,Samsung 100mm macro M50 1.7(x3), M28 3.5, M35 2.8, M100macro f4, M135 3.5(+others)
Posted 18/01/2012 - 12:18
I have the K28/3.5, the M28/3.5, the A28/2.8 and the K24/2.8. I used to have a M28/2.8 until it was stolen. I doubt that any of those lenses would disappoint you. If pushed, the K28/3.5 is probably the sharpest (as well as being the largest, heaviest and most expensive), but you really need to be pixel peeping to be honest. On the MX I would recommend the M28/3.5 as it is sharper than the 2.8 version, but smaller than the K versions and more in keeping with the body.
K.
K.
Posted 18/01/2012 - 21:28
The K 24/2.8 is fantastic IMHO.
Other suggestions: Tamron 24/2.5 or 28/2.5 Adaptall 2 - both very good. The 28 is very inexpensive. The Sigma 28/1.8 Mini wide is very good but prone to oil on the aperture and/or lens surface.
Vivitar, Tokina, Cosina, Bell & Howell, etc.?
I would prefer focus action to be same direction as Pentax 50mm and 80-200 I already own. Subject matter is mainly Scottish landscapes.
35mm film: MX (desire LX) and Nikon F100 (plus in storage P30 and Minolta Dynax 6)
Digital: Nikon D40
