Which Flash for my K7 ?
Posted 20/04/2011 - 20:01
METZ 50 AF-1 Digital, I have 3 and think they are great. See below for technical specifications
Flash output
• High max. guide number 50 for ISO 100/21° and 105 mm
• High flash number [e.g. 330 full flashes with NiMH rechargeable batteries (2100 mAh)]
• Flash delay 0.1 – 3.5 seconds (depending on energy source and flash output)
Basic configuration
• Vertical (-7/+90°) and horizontal (300°) swivel reflector
• Illuminated LC display
• Motor zoom for 24 – 105 mm illumination
• Integrated wide-angle diffuser for 12 mm illumination
• Flip-out reflector card
• Modelling light (permanent light to check the image illumination)
• Integrated autofocus flash metering
• Flash readiness indicator and correct exposure display on unit and camera
• Flash range display in LCD
• Automatic unit shut-off
• Metal base with quick lock (not Sony)
Ready for the future
• Firmware update via integrated USB socket
Camera-specific flash functions
• E-TTL / E-TTL II flash mode (Canon)
• i-TTL / D-TTL / 3D flash mode (Nikon)
• P-TTL flash mode (Pentax)
• Four thirds-TTL flash mode (Olympus / Panasonic / Leica)
• ADI flash mode (Sony)
• Camera-specific TTL remote mode (slave mode)
• Servo flash mode
Basic flash functions
• TTL flash mode
• Manual flash mode with 8 partial lighting levels
• HSS – high speed synchronisation
• 1st and 2nd shutter curtain synchronisation
• Manual flash exposure correction for TTL or automatic flash mode
• Automatic fill-in flash
• Flash bracketing
Very good product for the price!
Fletcher8
Flash output
Basic configuration
• Servo flash mode
• TTL flash mode
• Flash bracketing
Fletcher8
Fletcher8.
Posted 20/04/2011 - 23:44
The Sigma you have works fine on digital. You'd be changing just for the sake of changing. If I was you, I'd put the money for a second flash (preferably the same thing, so the interface is the same), or, if you don't use flash much, toward an extra lens.
Posted 21/04/2011 - 11:54
I'm not completely satisfied with my Sigma especially when I use it in TTL-mode to fill-in some shadows.The Sigma you have works fine on digital. You'd be changing just for the sake of changing. If I was you, I'd put the money for a second flash (preferably the same thing, so the interface is the same), or, if you don't use flash much, toward an extra lens.
It works perfectly in manual mode instead.
Posted 21/04/2011 - 11:55
Flash output
Basic configuration
• Servo flash mode
• TTL flash mode
• Flash bracketing
Fletcher8
Thanks FletcherMETZ 50 AF-1 Digital, I have 3 and think they are great. See below for technical specifications
Flash output
Basic configuration
• Servo flash mode
• TTL flash mode
• Flash bracketing
Fletcher8
I will test it as soon as possible.
Ciao
Posted 21/04/2011 - 13:14
And another vote for the Metz 50. P-TTL has been excellent so far.
Italy
Ciao
Alberto
