Which AA batteries for K-x??
Posted 20/01/2011 - 15:55
I bought these. And happy with them in my K-x. No idea how many pics I get from a set, but enough for me not to worry about it. And the charge indicator does stay on green for a while.
http://www.7dayshop.com/catalog/product_info.php?cPath=777_3&products_id=109612
Have you updated the firmware since you got the camera?
Posted 20/01/2011 - 16:04
Try Ansmann rechargeables. I have two sets and they seem to go on for ever. Worth the extra cost.
Posted 20/01/2011 - 16:28
The Lithiums I got with my K-m lasted ages, they are very good. They are expensive if you want to buy them everytime.
My advice would be to buy a couple of sets of Eneloops and a charger, then keep a new set of Lithiums in your bag for transferring into warm pocket should the temperatures drop (they seem to work better than Eneloops in the cold).
Apparently.
Apparently.
Posted 20/01/2011 - 16:35
People were raving about these over on the Oly user forum:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=370452825417&ssPageName=STR...
Dave
Dave
Posted 20/01/2011 - 20:30
I hope eneloops are good 'cause I've got some free with the K-x I've just ordered!
Posted 20/01/2011 - 20:31
I use Eneloops with my KX. I have had issues this winter with them flashing red even though they had been fully charged the day before. The temperature was about -5 deg C. The batteries are about 12 -14 months old and have been charged/used about 20 times.
I have the camera set on the auto-recognise batteries setting. Changing to manual selection of batteries made no difference - nor did the usual trick of loading a set and waiting a few minutes before switching on.
Anyone have any thoughts? Its certainly always good to have a set of lithiums in the bag! They are working fine again now its not freezing.
Geoff
Geoff
K10D,KX, DA 18-55, DA 17-70 AL(IF) SDM, DA*50-135, Sigma 70-300, DAL 50-300mm, Kenko 1.5x, loads of SD cards and even more optimism
Posted 20/01/2011 - 21:15
Batteries just don't like being cold - you need to keep them inside a pocket, so-to-speak , insulated from the cold .
let the education continue
Posted 20/01/2011 - 21:40
... which is why I have 3 batteries for the k10 and again for the new k5. Keep one in a warm pocket and 2 in the cam, change as necessary.
Bret
Bret
my pics: link
Posted 21/01/2011 - 03:14
I'm using Energizer Ultimate Lithium. Averaging over 1500 shots on a set. Energizer has several types of lithium but the ultimate ones really last longer.
Francois Quesnel
When taking pictures always think of those who will see them... a hundred years from now!
My gallery
My gallery
Posted 21/01/2011 - 03:21
I use Powerex 2700mAh, as recommended by a pro photographer in an English photo mag. I've also got Sony CycleEnergy 2400mAh, and Eneloop 2000mAh. They all seem fine, with the Powerex's top of the list.
Sam-Joseph
Pentax K7, Sigma 17-70 f2.8-4.5, Sigma 70-200 f2.8 APO EX, Sigma 70-300 APO, Sigma 1.4x TC, Vivitar 2x TC. Takumar 135mm f2.5, SMC Pentax A 50mm 1:1.7, SMC Pentax -M 1:4 200mm, Pentax X70
Posted 21/01/2011 - 16:15
Good point about the cold weather and batteries. I also had my K10 with its dedicated battery and that combo never faltered. I took a set of eneloops from my trouser pocket and they also struggled to power up the KX.
Is there a difference between the rechargeable technology used in the Pentax batteries and that used in the hybrid AAs? Or could it be that the KX doesnt like -5 deg?
Are all hybrids the same or could it be that the Powerex ones might behave better than the Eneloops if only because they have a higher capacity?
Would be good to get to the bottom of this so that I'm better prepared for next winter. Cheers all.
Posted 21/01/2011 - 16:25
Pentax batteries are rechargeable Lithium, hybrid AAs are NiMh.
Apparently.
Apparently.
Milton Keynes
What AA batteries are you using??
Fred de Klein
Pentax K-x, Standard Lens Kit, 18-55 & 50-200,
Pentax SMC DFA Macro 100mm F2.8
... soon to be strengthened by Tamron 70-300mm F4-5.6
Milton Keynes, UK
Have mercy ... requires a lot of help
