K20D Arrived - Woo
Posted 24/01/2011 - 16:01
I am sure you will enjoy it. Just make sure that you got a memory card as well as no mention of this has been made
Use the time till tomorrow to get someone to charge up the Battery as this can take quite some time and you got all night to charge it.
Kind regards
SmutjeUK
It's nice to be nice!
SmutjeUK
Posted 24/01/2011 - 16:20
Ordered a 4GB card with it and a spare battery but will add some more memory cards soon.
Posted 24/01/2011 - 16:28
Well done, now . . .
Just about every question that you are likely to have, and you'll have plenty, has probably already been asked here, and answered.
The search facility on this site will probably provide all the answers you need. It's best used after having read the camera's instruction manual from cover to cover, . . . twice, and then referred to if you can't make something work.
A number of first steps:-
1: Check and update the firmware if necessary.
2: Do a factory default so that you start at the same place we all started before making any menu changes.
3: Read the manual again.
4: Now find the custom menu option #36 that allows the use of the aperture ring on manual lenses, and set it to "Permitted". That'll avoid one question later.
5: Set the focus point selector to 'Centre Point' (fully clockwise - extreme right most option) and for now, focus your images at the centre point, and re-compose the shot. You can play with the other settings later.
6: Don't use the 'Spot metering' option yet, unless you know how to use it properly. Instead, use either of the other two options for metering.
7: Before fitting a lens, adjust the dioptre setting correctly. Leave the body cap on if it's one of the translucent shipping caps and point the camera at a bright light source other than the sun. Adjust the dioptre setting so that the framing lines on the focussing screen are tack sharp.
8: Fit a lens, you're good to go. Enjoy your new friend.
Posted 24/01/2011 - 17:11
Mike-P wrote:
He has had a few DSLR's already Peter, including a Pentax.
Apparently.
Apparently.
Posted 24/01/2011 - 17:54
chrism_scotland wrote:
Well my K20D has arrived today from SRS, although due to having to order from different places I've got no lens to play with tonight
Although tommorrow I should be spoiled for choice with a 16-45, 35mm, 70-300 and flashgun all to play with!
Nice one Chris!!! Well my K20D has arrived today from SRS, although due to having to order from different places I've got no lens to play with tonight
Posted 24/01/2011 - 21:30
i have had my k20d for a few weeks now & enjoying it very much good choice hope you enjoy it as much a i do
phill
phill
Posted 24/01/2011 - 22:35
I hope it gives you as much pleasure as mine has given me Chris.
(FYI, current firmware is 1.04.)
Posted 24/01/2011 - 23:11
Enjoy your new purchase Chris. It is a fine camera, excells in the Studio.
Some Cameras
Posted 25/01/2011 - 09:28
Flash Gun and 70-300 arrived at my work now, just waiting for my 35mm and 16-45, can't wait to have a play tonight!
Posted 25/01/2011 - 09:41
I've picked up the Tamron that Dave had on the Classifieds, I'll see what I think, I got a bit of a bonus this week, work bonus on Friday and I got £100 off the airline for taking another flight so I might order the Pentax 55-300 off Park if I'm not impressed with the Tamron,
Posted 25/01/2011 - 12:27
Chris,
I've sent you a PM on the Tamron 70-300 V Pentax debate 55-300!
Dave
Dave
Posted 25/01/2011 - 14:09
All my kit has now arrived woo! Will report back this evening one I've had a play with it all!
And arranged to add a battery grip to it in a few days.
Edinburgh
