Warning!
beginner
Posted 30/11/2008 - 12:18 Link
I was out and about this morning trying to make the best of the frosty conditions!.........I managed 6 shots with the K20D before the cold took over!....it stopped working at -7!...I went back to the car for 10 mins to warm it up again and it worked fine!,it just wouldn't start up in the cold!
bforbes
Posted 30/11/2008 - 14:17 Link
The manuals for K10D and K100D quote the operating temperature for cameras use as 0 deg. C to 40deg. C. Getting to minus 7 was a bonus. I was out yesterday at Bamburgh and thought I was having the same problem but then I realised I had not switched it back on after a lens swap. Too many buttons and too many Years
hefty1
Posted 30/11/2008 - 14:35 Link
That's one of those times when you want to slip an MX into your bag - fully mechanical cameras should be able to keep snapping whatever the temperature (that's one of my justifications anyway )
Joining the Q
bforbes
Posted 30/11/2008 - 14:40 Link
Hefty1 where do you get the digital film from ????
Don
Posted 30/11/2008 - 14:41 Link
cut the sleeve off an old winter parka.
sew some velcro to the cut edge.
put your camera in that with the lens poking out the cuff end.
add a chemical hand warmer.
you're good to go to forty below.
When in doubt, ask a cannuck
hefty1
Posted 30/11/2008 - 14:49 Link
It's a special digital film that comes in a roll and has to be exposed to mysterious chemicals before you can play with the image in Photoshop. No preview on the back of the camera either I'm afraid...
Joining the Q
beginner
Posted 30/11/2008 - 14:50 Link
You forgot to mention the double-glazed lenses!:
Mac
Posted 30/11/2008 - 16:10 Link
Was out in the COLD last night, so took one of my Spotmatics with a Takumar 1:1.4 50mm, instead of any of the digitals.
Of course, it worked a treat - as it has for 40+ years.
How come I can't stop looking at the back of the film door after each shot?
I should glue a mirror back there so I'd have an idiot to look at at least
Mac from Montreal
bforbes
Posted 30/11/2008 - 16:39 Link
Just a thought! In a topic "shutter counter" someone commented that Photome records the ambient Temp. that the photo was taken at in the EXIF information. the question was asked why did the camera have a thermometer. Is it part of a system that closes down the camera if you try to use it outside the operating range? Or did beginners K20D just not work becuase the batteries were too cold.
beginner
Posted 30/11/2008 - 16:59 Link
Interesting thought BF!....We may have to add antifreeze during the winter service!,,,,and I wonder if there is a thermometer?....
Posted 30/11/2008 - 17:15 Link
We were out at -2C today and both K10Ds were operating normally, but I guess -7C is pushing it a bit. Keep the camera warm, inside a coat perhaps, and only bring it out to take the shot, otherwise it's back to film!
Get much colder than that and film becomes brittle and tears when wound on, exposed metal parts of the camera stick to exposed skin...roll on Summer.
Don
Posted 30/11/2008 - 18:42 Link
not to mention interesting patterns on the film from static electricty making sparks!
wasleys
Posted 30/11/2008 - 20:55 Link
I'm just back from Chile and at dawn in the Atacama at 4,500m it was -12°C. No problems experienced with my K10D which had been kept warm going up and was in a bag between shots. I had made sure the battery was fully charged the night before.
pentaxian450
Posted 01/12/2008 - 00:18 Link
I often use my K10D and K20D at temperatures much lower than that. Once the power is "on", just don't turn it "off". In winter time, I regularly use my cameras at -20. You have to be careful about condensation when you go back to a heated place...
Don
Posted 01/12/2008 - 00:41 Link
while outside, place in ziplock baggie, suck out excess air, seal, then bring inside, and allow to aclimatize to room temp before opening.
Edited by Don: 01/12/2008 - 00:43
