Vanishing Posts
Posted 02/04/2009 - 13:53
I posted in the very early hours this morning and it still is there.
Posted 02/04/2009 - 15:53
Very occasionally I write a post, get distracted and forget to press Add Comment. Is this a possibility?
I will check now to see if has been deleted.
Posted 02/04/2009 - 15:56
I can confirm that the post was never made. It might have failed before it was entered into the site database.
Posted 02/04/2009 - 16:00
I think this is called: " Having a grey moment". Very occasionally I write a post, get distracted and forget to press Add Comment.
It happens to me all the time.
Martin.
Posted 02/04/2009 - 16:35
i knew i had seen this a couple days ago,
https://www.pentaxuser.com/forum/topic/Rooks-repost--it-disappeared-11115
and i did see the original post to,
just keep snapping,
nikon d300 + battery grip.
sigma 150-500mm apo dg hsm os
sigma 170-500mm apo dg
Posted 02/04/2009 - 16:55
I saw the protest girl post and even made a comment on it!! hmmm...
Posted 02/04/2009 - 17:40
The 'Protest Girl' thread is still there but Hyram's response within that thread is not.
I use 2 computers to access this forum on one I checked 'remember me' when I logged in so donot need to log in and have no problem posting. On the other I have not checked 'remember me' and find that if I take a long time composing a posting then my session has timed out and the system no longer knows that I am logged in and when I click the 'add comment' button my post is 'lost somewhere in cyberspace' as only logged in members can post.
Have been caught a few times so I now save my posting in the cut and paste buffer before hitting the 'add comment' button (Control+A to select all of the text I'm writing, then Control+Insert to put it into the Cut and Paste buffer). Then if my post dosn't appear at the end of the thread I log in again and retype my comment by pasting from the Cut and Paste buffer (Shift+Insert) before pressing the 'add comment' button. [keystrokes are for PC]
Always works the second time so I've just put it down to login timeouts...
Good luck
Bob
Bob
Posted 02/04/2009 - 17:55
Well I don't think that I was "having a grey moment" and the log-in timeout seems a likely explanation
Hyram
Posted 02/04/2009 - 23:53
Yes, it was by me, and I have seen my post, oh, well, posted, but when I came back some minutes later it disappeared, so I reposted.i knew i had seen this a couple days ago,
Weird... Reality glitches, someone's tinkering in the Matrix?
Kind regards,
Michal R. Hoffmann
Michal R. Hoffmann
Posted 03/04/2009 - 15:26
how interesting, I didn't know those keystrokes and was just about to assume you were using a mac and post the PC ones I use, Ctrl+C = copy and Ctrl+V = paste.[keystrokes are for PC]
Just tried it and you're absolutely right, your key combos work too! learn something new everyday
but it does help
but it does help
Posted 03/04/2009 - 22:23
Mongoose: these shortcuts date before MS Windows, I'm not sure but I think that Ctrl-[C | V | X] were introduced (at least in PCs) with MS Windows. I remember using Ctrl / Shift + Ins at univ learning programming and it was a text environment.
Kind regards,
Michal R. Hoffmann
Michal R. Hoffmann
Posted 03/04/2009 - 22:50
As did I
Posted 04/04/2009 - 08:23
sanderscapes wrote:
My missing post asked the OP if he had photographed the armoured car that some protesters had driven into London on that day.isdky wrote:
As did II saw the protest girl post and even made a comment on it!! hmmm...
Perhaps all our posts our monitored by some secretive government department
Hyram
Deepest Hampshire,
England
Both have vanished
Has anyone else had a problem of vanishing posts :
