Updating firmware
Posted 03/07/2013 - 17:17
No, you won't need a huge card to update the firmware. The files are actually quite small.
Posted 03/07/2013 - 17:37
Thank you I'm looking forward to learning how to use it as soon as I can get out! I am impressed by the manual - a solid little lump of paper!
Posted 03/07/2013 - 18:13
Lancer wrote:
32mb card?
Yes probably 32mb is about the minimum. Note that's megabytes not 32Gb (ie Gigabytes!) You'd be hard pressed to buy one that small now, but it doesn't have to be that small.32mb card?
Posted 03/07/2013 - 18:56
OK - I am an utter wazzock! The card is 16gb so more than sufficient! I am going back to bed - I will hopefully be more recovered and not as stupid tomorrow
Thanks for your help chaps.
Posted 03/07/2013 - 19:00
Yes, a 16Gb is fine. Delete the file from the card once you've performed the update, and make sure the battery is fully charged before you start to prevent it failing part way through.
Posted 03/07/2013 - 22:18
JAK wrote:
b - bitsLancer wrote:
32mb card?
B - Bytes
m - milli
M - Mega
g - acceleration due to gravity
G - Giga
Posted 03/07/2013 - 22:36
A 32Mb card in a K-5 shooting RAW would hold one image
Posted 03/07/2013 - 23:02
It wasn't long ago that was considered a huge amount of memory and the first cards with it cost a fortune.A 32Mb card in a K-5 shooting RAW would hold one image
Posted 04/07/2013 - 07:26
my first pc (a 486) had 4 mb of memory, and 640 mb hard drive, and that was a pretty good spec!
Posted 04/07/2013 - 08:08
JAK wrote:
Indeed. I had a massive brick sized 20Mb Hard drive once. think it was a 5 1/4" platter job. here's a comparison pic with a modern sized one.Smeggypants wrote:
I can also remember when 4Mb of SIMM Ram chips were over a £100. A few months ago I bought 24GB of RAM for the same price. That's a 6000% increase/£
Posted 04/07/2013 - 09:42
Hah, you measure RAM in MB????I can also remember when 4Mb of SIMM Ram chips were over a £100. A few months ago I bought 24GB of RAM for the same price. That's a 6000% increase/£
Long, long ago in a distant universe I teamed up with a pal at Uni and built one of the first microcomputers available with a grand total of 0.5K (yes K) of RAM. A term later we had got a little bored with having to write assembler for everything and spent a fortune (£80 or almost an entire terms 'income') expanding the RAM to 2K which let us run a TinyBasic interpreter on it -- luxury!
Posted 04/07/2013 - 10:01
I still have the 'Firmware' thingy which came with my K10D -- never had it 'updated' as cannot understand the instructions and it still WORKS OK so why bother ?
Posted 04/07/2013 - 10:28
Depending which version you have installed you may be missing out on features and bug corrections as follows:I still have the 'Firmware' thingy which came with my K10D -- never had it 'updated' as cannot understand the instructions and it still WORKS OK so why bother ?
Changes to V1.20
1. Correspond to PENTAX REMOTE Assistant 3
Changes to V1.11
1. Correspond to development in the RAW data camera when multiple exposing.
2. When built-in flash is used the luminescence control by the trailing-shutter-curtain sync was corrected.
Changes to V1.10
The following function has been added in version 1.10
1. Wireless control of external flash through built-in flash.
2. Instantly return to centre AF point by one push of button in AF select mode.
3. Possible to change ISO setting by dial at TV/AV mode.
4. ISO setting change by dial while the ISO setting is being displayed on the LCD by pushing OK button.
5. Green button function in M mode is available at TAv mode (Hyper manual).
6. AV and TV switch by dial at P mode.
7. Instant return to the default value by green button at strobe light compensation.
The following contents have been corrected.
1. In rare case, vertical stripe at long time exposure.
2. Released “B exposure” and show battery empty sign when using B mode.
The procedure is normally quite straight forward and painless
Posted 04/07/2013 - 11:58
It sure was. My first PC was a 286, had 1MB of memory and a 20MB hard drive. my first pc (a 486) had 4 mb of memory, and 640 mb hard drive, and that was a pretty good spec!
The only digital camera I've had up to now is an Olympus 370 (uses xD format) - I've used film slrs for over 35 years, (Canons) but the K30 ticks all my boxes!
