Two more front ends
Posted 24/02/2014 - 13:33
redbusa99 wrote:
with regards the WR/dust ingress situation why can't they be labeled with an IP rating , at least we could all check the level of protection to a given scale.
That would mean testing and certification at an accredited independent testing facility. An expensive exercise indeed. You could approach such an establishment and get a quote for testing but be warned, they will test to failure to determine the highest protection levels.with regards the WR/dust ingress situation why can't they be labeled with an IP rating , at least we could all check the level of protection to a given scale.
Posted 24/02/2014 - 15:06
RalphHardwick wrote:
I have the DA* 50-135 and 60-250. Personally I would rather have a TC and retain the IQ. However if the 135-380 is DA* quality then I would be very interested.
I have a DA* 50-135 and a Sigma 135-400. While the IQ of the 50-135 is slightly classier I've never once felt the 135-400 was lacking becuase of it's IQ. It only cost around £300 as well. You can bet a DA* 135-380 would be well over a grand
Posted 24/02/2014 - 22:16
Smeggypants wrote:
Fair point but I have a bit of a fixation on dust and weather sealing which rules the Sigma out for meRalphHardwick wrote:
I have a DA* 50-135 and a Sigma 135-400. While the IQ of the 50-135 is slightly classier I've never once felt the 135-400 was lacking becuase of it's IQ. It only cost around £300 as well. You can bet a DA* 135-380 would be well over a grandI have the DA* 50-135 and 60-250. Personally I would rather have a TC and retain the IQ. However if the 135-380 is DA* quality then I would be very interested.
If they did bring out a DA* 135-380 I would definitely consider swapping the 60-250 especially if it was constant f2.8. I can dream can't i
CaptureLight Ltd
flickr
CaptureLight Ltd
flickr
Posted 24/02/2014 - 22:59
I've used my 135-400 in duty and moderately rainy environments without problems. As Gary Cabstar says all the Pros bung on a plastic cover anyway. I wouldn't use anything in a sandstorm or storm without external cvoering
A DA* 135-380 constant 2.8 would probably cost about £10,000
Posted 25/02/2014 - 14:27
My next trip is into the hinterland of Iceland for 2 weeks including, dusty roads, waterfalls, geysers, volcanic ash and a whale watching trip on a boat. In 2015 I'm hoping to drive the Southern Algeria to the centre(ish) of the Sahara desert.
Although a cover would be beneficial at times I need an ongoing degree of dust resistance even when stored in the vehicle (Land Rovers aren't renowned for their dust resistance:blush.
Thanks for the info though
As I said............I can dream
CaptureLight Ltd
flickr
CaptureLight Ltd
flickr
Posted 25/02/2014 - 16:28
wadna wrote:
"An 18-70WR is also a welcome addition. Hopefully it might be better built than the current 17-70"
What's wrong with the build quality of the 17-70? I've only had one a relatively short time (replacing a Sigma 17-70) & so far I have no problems with it's build quality. Certainly it's in a different league to the Sigma.
The answer is that build quality is variable. I have rejected three examples that had unacceptably wobbly barrels and sloppy focus rings (and plenty more examples of this have been reported elsewhere and even demonstrated online) but no doubt others will report that their 17-70s have tight barrels and perfectly damped rings. IMHO Pentax lens QC still has room for improvement - but that's a different thread."An 18-70WR is also a welcome addition. Hopefully it might be better built than the current 17-70"
Jim
Posted 25/02/2014 - 21:40
Jimbro66 wrote:
Jim
Thanks Jim. I confess my 17-70 zoom creeps as I carry it which is a source of annoyance.wadna wrote:
Jim
Regards,
Ian.
Posted 25/02/2014 - 22:02
The build quality of my 17-70 is excellent, as is the image quality, no complaints at all regarding this. I would also say the build and IQ of all the Sigma lenses I own is also excellent, although I'm not a fan of the finish that Sigma employ as it's too prone to marking and scuffing.
I think Pentax are well capable of releasing a DA lens with excellent IQ, they have proved this with the 17-70 and the 18-135, both of which seem to suit most of their owners in IQ terms. I too suspect the lens will not be FF capable, not a big issue for me. My suspicion is that if and when Pentax go FF, it will not be with a DSLR. BTW, I base that not on any known facts, just a gut feeling.
stroud,glos
