Tuff question
Posted 29/08/2011 - 12:58
Extract from Pentax Forums: -
Metz 58 and HSS
It has been documented that the Metz 58 AF-1 flash unit does NOT function as a controller/master when trying to wirelessly activate a second, off-camera flash in High-Speed Sync. However, the Metz CAN be used as the HSS slave. This seems to be a bug, or something overlooked in the development of this flash for Pentax.
I had called Bogen Tech Support (U.S.) and related the issue. I did candidly tell the gentleman that it was fortunate I still had a Pentax 540 as my second flash, rather than a second Metz, so that IT (the Pentax) could be used as controller for the Metz. (Needless to say I didn't go into detail about how the placement of the Metz sensor causes it to be rather "hit & miss" as far as reliability.) His response was, "Well it sounds like you've been able to work out a solution to the problem." I would have rather heard, "Yes, we're working on a firmware update which should be out shortly"!
Well, he did at least forward my concerns to the parent company in Germany, and I have received their response:
Thank you for your e-mail enquiry of 02 June 2009 .
We regret that in wireless “Pentax Remote Control” the master/controller function in HSS mode is not available by the flash unit “mecablitz 58 AF-1P digital” (for Pentax).
We have forwarded this problem to our developing department (laboratory) to have it checked whether it is possible to retrofit this function to flash unit by a firmware update.
Unfortunately, I was told at the present there is no firmware update in preparation for this type of flash unit.
We regret to have no other info rmation for you and remain
With kind regards
Wolfgang Becker
Technical Support
Too bad. It's disappointing that they tacitly acknowledge the need to buy into their competion to get the full functionality out of -their- unit, rather than fix the problem. That being said, this issue is of no concern for the majority of uses, and the Metz 58 is still a great flash. Just thought I'd share this follow-up for anyone interested.
Paul
Read more at: http://www.pentaxforums.com/forums/pentax-flashes-lighting-technique/62768-metz-...#ixzz1WQ0QEF00
DOnt know if this helps you......
Metz 58 and HSS
With kind regards
Wolfgang Becker
Technical Support
Paul
K5's (2)both gripped, K10d gripped, Pentax 28-90 f3.5, Sigma 18-250mm, Sigma 150-500mm. Sigma 105mm f/2.8 EX DG Macro, Sigma 10-20 f.4-5.6.EX DC, Hoya 135 f2.8, Take on 28mm f2.8 Pentax AF360 flash, 2 fill in slaves. 30 metre remote release, Rt angle viewfinder, Giotto NOT 3261B Tripod with Manfrotto 808Rd4 ball head, Manfroto 4861RC2 monopoly, shoulder stock, various filters etc, Panasonic SET HBS HD Video cam, Tamrac Explorer 8x backpack and a sore back.....
Photography is an index for measuring futility and pride.......
Paul
:wink
http://s743.photobucket.com/home/pg20_photos/index
https://www.flickr.com/photos/pg20
Paul
:wink
Posted 29/08/2011 - 13:21
paulgee20
Thanks for your response! I have read the above before, but it is in relation to the 58 AF1. I am still trying to establish if the 58 AF2 can do HSS as a Master controller?
I was very interested in HSS as can't seem to find a wireless trigger capable of P TTL. Fingers crossed perhaps someone will produce one.
Fletcher8.
I know that the Metz 58 AF-2 can be used as a slave or master, but what I can't seem to find out is this:
Can the Metz 58 AF-2 in HSS as a master control a Metz 50 AF 1 in HSS as a slave? or does anyone know of a wireless trigger that would provide P TTL?
Many Thanks
Gareth
