Trigger flash in Manual mode K110d
kemp
Posted 24/05/2009 - 23:05 Link
amoringello wrote:
The set up did still work, but only up to a tv value of 180. Is that normal?
See my post above.
Sorry! Totally did not see that post! This could have ended a long time ago Cheers you too!
Mannesty
Posted 25/05/2009 - 06:49 Link
kemp wrote:
Thank you Mannesty as well, You're always around to help out!
I know it can be annoying trying to figure out what someone new to trade is on about!
You're welcome and well done for sorting it out. It's not annoying at all. I've spent my working life in the IT service industry and finding solutions to problems is what I do.
It makes a nice change to have a relatively simple problem to sort out.
Enjoy your setup.
PS: You can use your AF360FGZ with a higher synch speed than 1/180 sec. You need to set the flash and the body (if yours will do HS Synch, consult your manual) to High Speed Synch mode. In this mode the flash will trigger a number of times for one exposure, but at reduced power. I'm not sure it'll work with your Cactus trigger though but it does work with the camera/ flash sset in wireless mode. This should work reliably up to about 4 metres from camera to flash but it also depends on the ambient lighting conditions.
