teleconverters
Lancer3397
Posted 05/08/2013 - 23:31 Link
I've done quite a bit of reading lately and I realise with a TC I'm going to lose at least 1 stop of light, fine, but I'm also concerned that I retain autofocus function and don't lose too much image quality.
I've read recently that I should really consider the sigma 1.4 EX DG if I'm using a sigma lens as they are designed to be matched together.
alternatively, the Tamron PZ-AF MC 1.4 and the Kenko PZ-AF 1.5 are talked about quite highly, however, the Tamron appears to be double the price of the Kenko but I have no idea if it justifies that price difference?
I did read one review that raved about the Tamron and said it lost no quality at all which I just don't believe. I realise there are lots of Teleconverters and you really do get what you pay for, but retention of autofocus is a big plus for me and I don't want to go beyond 1.4-1.5 as far increase in mm goes.
can people comment on the Kenko and tamron at all? is the tamron worth £130 notes more in price?
Pentax K3, DA 18-55 WR, Sigma 50-500 EX DG HSM, Pentax M-50, a bucket load of SD cards, some lights and a lightbox
Algernon
Posted 06/08/2013 - 08:02 Link
What lens do you want to use it with?
Lancer3397
Posted 06/08/2013 - 20:51 Link
at the moment I have the DA L 55-300 but I'm also casting around for a faster 300 tele if I can find one at a reasonable price.
Posted 06/08/2013 - 21:19 Link
The 55-300mm is a great lens, but it doesn't take to teleconverters too well. I really wouldn't bother with that path.
You'd be much better served with the Pentax 300mm and TC.
Algernon
Posted 06/08/2013 - 21:23 Link
The 55-300mm works very well with a TC.
This was at about 280mm + TC Handheld K-5 200ISO
Edit: Just noticed you have the 55-300mm that hasn't
got Quickshift, in which case I would change the lens
first for the more expensive version otherwise it
huns for focus quite a bit. It's better to set the focus
at infinity before using AF
Edited by Algernon: 06/08/2013 - 21:30
Posted 06/08/2013 - 21:24 Link
Not with mine it didn't, which one was that Algi?
Algernon
Posted 06/08/2013 - 21:30 Link
Jessop 1.7x TC also works well with the Sigma 150-500mm.
That shot was straight from a JPG although I took RAW as well.
Posted 06/08/2013 - 21:35 Link
Good to know, many thanks!
Algernon
Posted 06/08/2013 - 21:43 Link
It also allows you to get in close, although this was the 55-300mm at
120mm + TC
Lancer3397
Posted 06/08/2013 - 21:55 Link
so what is the name of the pentax 55-300 with quickshift because that is my one gripe with my existing DA L 55-300 ED, it hunts......a lot.
for airshows I want a fast 300 lens to get round that, sometimes the 55-300 I have just hunts and I have to zoom right back to 55 to re-acquire and have it lock in.
the jessops 1.7 TC sounds good. is there more to the model number I should be looking for than just jessops 1.7 tc?
I had been considering the kenko 1.5 pz-af or the tamron pz-af 1.4 but am struggling to see why the tamron is double the price of the kenko.
what sort of figure should I be seeing the jessops priced at?
do you shoot moving action with your 55-300 + TC setup? because that is my main use, action ie air shows, ie fast moving aircraft.
Posted 06/08/2013 - 22:01 Link
SMC Pentax-DA 55-300m has QuickShift, SMC Pentax-DA L doesn't.
Mike-P
Posted 06/08/2013 - 22:02 Link
According to this thread that is all down to user error and not the lens.
Using a teleconverter on the 55-300mm will make the AF a whole lot worse for airshows.
Edited by Mike-P: 06/08/2013 - 22:05
Lancer3397
Posted 06/08/2013 - 22:06 Link
great, thanks for that.
if I can source one of these I think that will make me a lot happier, get a good TC to go with it and then sell my existing 55-300.
Mike-P
Posted 06/08/2013 - 22:08 Link
The Jessops converter is (as far as I can tell) exactly the same as the Teleplus version I currently have advertised in the sales section.
Lancer3397
Posted 06/08/2013 - 22:33 Link
well as long as it works in AF mode with the modern lenses I don't mind.
I was just leery of some teleconverters because a lot of older ones won't do AF and I 've seen some threads advising people to get a teleconverter that is marked PZ-AF to address that issue.
