Sunsets
Edit: Just noticed you bracketed - you can experiment with HDR then!
John
If you took 150 pictures at various speeds and bracketed you should have plenty of material to get something decent, as long as you shot RAW. As davidstorm says, shoot to expose the highlights correctly. You should then normally have enough information in the 14-bit sensor data to be able to lift the shadows as far as you need, without seeing too much noise.
As it happens, I'm just experimenting with skies and shot a sunset the other evening. It's nothing special but gives you the idea. I suspect your in-camera JPEGs look something like this:
http://www.flickr.com/photos/waypointcharlie/6968885486/in/photostream/lightbox/
Post processing from a single RAW file you can lift the shadows like this:
http://www.flickr.com/photos/waypointcharlie/7105942159/in/photostream/lightbox/
Or you can HDR like this:
http://www.flickr.com/photos/waypointcharlie/6959874622/in/photostream/lightbox/
Personally I don't like the HDR, although I'm not experienced at the technique and I've since found that auto bracketing in M mode varied the aperture considerably, which may not have helped. In fact, you'd be forgiven for thinking that the in-camera JPEG with the dark shadows is the best of the bunch!
... my understanding is the dynamic range functions are applied to RAW as well as JPEG ...
The RAW file is just the digital equivalent of an image taken on slide or negative based purely on shutter speed, aperture and ISO - just like a film camera. It isn't processed at all. Most software packages, however, use the camera settings for reconstituting the image for further processing (or development.)
Most DSLRs take a 12 bit image. Newer ones including the K-5 take a 14 bit image. By combining images in suitable HDR software that can be extended further up to 48 bits.
There's no reason for HDR shots to look over the top. Without HDR my original jpeg file for the recent Buildings comp looked like this:
The 5 exposure HDR makes a world of difference:
John
I photographed a silver car on a bright day with highlight correction on and off. The RAW outputs seemed to confirm that highlight correction did get applied, but I appreciate that sort of test is crude and not scientific. Ah, I notice that dpreview think the dynamic range corrections are also applied at RAW level. I'm not saying they're right, just more likley to be right than me!
http://www.dpreview.com/reviews/pentaxk5/14
http://www.dpreview.com/reviews/pentaxk5/16
I can see that HDR has its place but I think it takes skill and an artistic eye to achieve a result that can pass as realistic, although realism is often not the intent. I'm always being told to darken my skies but when skies become a lot darker than the ground my brain says something looks wrong.
RAW format is a CMOS sensor output format saved without
processing.
John
However, there is no application of colour temperatures, styles, etc. and the save is lossless.
processing.
If you've got time to waste test it for yourself. I reckon it does affect the RAW data.
Anyhow, that's a really nice twilight photo. That one certainly doesn't need any extra detail in the dark foreground. The picture is of that interesting dark red sky so detail in the foreground might even detract. There's nothing wrong with silhouettes!
As to whether highlight and shadow correction were turned on would make any difference, personally I doubt it would have made much of a difference either way. That function is mainly useful on sunny days (remember them?!) to help keep detail in the shadows and to stop highlights being burnt out. You don't need detail in the shadows here and the sky certainly isn't burnt out!
John
Perhaps the kind lady from Pentax could tell us?
John
Turnberry,
Ayrshire
on my return I had a thought that it might have been better to have highlight and shadow correction on.
Would this have given me a better dynamic range.
