Stubborn lens hood - help
Posted 18/01/2011 - 15:04
The lens hood should be smooth and slick, so perhaps check out the plastic bayonet to see if something has been damaged. Don't force anything.
Posted 18/01/2011 - 15:05
doesn't seem right to me... you sure you didn't mixup a different hood from another lens?
something is warped or damaged.
Talcum powder worked for me.
Colin
Edmund Burke (1729 – 1797)
Posted 18/01/2011 - 22:21
Thanks for replies, had a look at the hood, it doesn't seem to be damaged or misshapen at all and it's definitely the correct hood.
The edges have a 'worn' look to them, as it rubs on and off the lens.
I gave it a clean with some damp cotton ear bud thingys.
They were covered in black grime by the time I'd wiped all round the hood bayonet and end of lens.
The hood seems to fit on and off a lot easier.
I guess it was a build up of grime. (now before you say, I'm not a filthy chap :blush
Will keep an eye on it.
Ali
ist* DS & Ricoh GR
Ali
ist* DS & Ricoh GR
Posted 19/01/2011 - 11:49
I've had similar problems with my 16-45 and after cleaning the black grime off it fits fine. (It would appear to be very fine worn plastic)
Not really bothered me as it fits fine after cleaning.
George
George
Posted 19/01/2011 - 12:36
My 16-45 is like new but the hood is very tight to get off. Always has been too.
Posted 19/01/2011 - 13:26
My 16-45 has always been the same. I clean it every so often and it helps a bit.
Posted 20/01/2011 - 01:23
A bit of lead pencil on the hood connector, may do the trick.
KR, Pentax 55-300 DAL, Pentax DA 17-55, Pentax 35-80, Generic grip, Generic remote, Nissin Flash. HISTORY - MZ 50, MZ 60, *istDS, KM, K20D, Nikon F60, Nikon F90. Large assortment of Point and shoot film and Digital, Sigma 70-300 APO DG, Samyang 500mm mirror lens, Sigma lenses of all assortments. K20D now sold. Sad to see it go, but makes room for an eventual upgrade to the K5 or the K4?
Scotland
My hood on the 16-50mm is really tight to undo off the lens when it's inverted. You can see rubbing on both lens and hood. It can also be stubborn to get off once it has been on the 'right' way, when I come to pack up.
I was thinking it needs a bit of 'lube' to help with the stiffness, but prob not great idea to get 'lube' around lens front!
Any suggestions?
Ali
ist* DS & Ricoh GR
