St Peters Sunderland
Posted 25/06/2011 - 16:14
I would have liked to see you use the symmetry of the church a little more. Where you have stood makes the viewing a bit awkward. In the first picture I would have used the floor tiles to line myself up and stood centrally with the pews drawing the eye into the picture.
K5, LTD 15 SIG 30, SIG 105.
Posted 25/06/2011 - 17:51
They looked blurred to me. Presumably wide aperture due to available light.
There's no isolated/main subject where you can focus on to make use of the shallow DOF. So my comments on ...
picture 1] - Shoot closer to the top of the lectern, so that's the main subject then the OOF background works
picture 2] - shoot from a more interesting angle, i.e. floor level, and so the end of the pew or lectern is the main subject. or shoot close up to the contents of the lectern, dogma book, papers, etc with a wide angle and use the narrow DOF I mentioned in picture 1
You're pics above are kibnd of indoor landscapes and lacking a main foreground subject you really need a wide depth of field to capture it IMHO .... tripod or held on a solid surface
Posted 25/06/2011 - 22:09
I agree with the two comments above and would offer another opinion.
I don't know how you metered for the exposure in shot #2 but although you've maintained beautiful light in the dark areas you've burned out the stained glass window on the right where there must surely have been some glorious colour. A good tip is to use the EV compensation on your camera to under expose, say in steps of 1/3rd at a time. If you shoot in RAW you can recover the dark areas in Photoshop but retain detail in the highlights. I've shot inside cathedrals and have gone down as far as two full stops under exposed in certain conditions to maintain detail in the windows.
Posted 25/06/2011 - 22:46
Agreed on the nuderexpose to retain the window detail.
If the K-t has the dynamic range of the K-5 then it would be a doddle to expose for the windows and recover the rest
Posted 25/06/2011 - 22:54
Are we allowed to do the nuderexpose thing in this forum?Agreed on the nuderexpose to retain the window detail.
I agree with the previous comments - the extreme range of lighting in this sort of situation is always hard. After taking a shot use the histogram to see whether the exposure was suitable - if it is burning out the windows then you can turn the camera to the window, half press the shutter or use the AEL button, then reframe the shot and take it with an exposure that is more suited to the window.
Posted 25/06/2011 - 23:02
karma mechanic wrote:
hehe - I saw the typo after I'd posted it but chose not to edit it, just for fun
Posted 25/06/2011 - 23:34
I did a quick edit on the first one to show what JamieT mentioned.
[IMG]http://i941.photobucket.com/albums/ad254/weldingblues/Modified%20forum%20shots/StPeters-Philstaff.jpg[/IMG]
I will remove the edit if required to do so.
Colin
Edmund Burke (1729 – 1797)
Posted 26/06/2011 - 16:48
Thanks guys for the feed back I will return to the Church at some point and take on board your comments which are very helful and hopefuly will return with more pleasing photos of the day.
Regards Ian
Regards Ian
Posted 28/06/2011 - 10:55
[IMG]http://i23.photobucket.com/albums/b399/philstaff/IMGP5453.jpg[/IMG]
Not the same church but I ave tried to make the flowers a focal point and retain the detail in the window.
Ian
Ian
Posted 28/06/2011 - 20:31
much prefer the last one even if the WB appears off....
(very aware that WB is an absolute pig if there are different light sources in play, i.e. tungsten inside and sunlight).
Bret
Bret
my pics: link
Posted 28/06/2011 - 21:05
That's a much better balance of light although the window could still do with darkening down a little.
David.
David.
Posted 28/06/2011 - 21:22
Boost to the colours in the window seems to help?
[IMG]http://i1081.photobucket.com/albums/j347/Jamie_Kx/IMGP5453.jpg[/IMG]
Posted 28/06/2011 - 22:26
A slight modification to levels etc results in this.
[IMG]http://i941.photobucket.com/albums/ad254/weldingblues/Modified%20forum%20shots/churchcopy.jpg[/IMG]
Colin
Posted 29/06/2011 - 09:49
Thanks again guys for the help I will continue to work on indoor shots and hope to get better results in time.
Regards Ian
Regards Ian
[IMG]http://i23.photobucket.com/albums/b399/philstaff/IMGP6170.jpg[/IMG]
I took these two shots inside ST Peters Church in Sunderland recently. This was my first with the Kr inside a building the shots were taken hand held with available light. Can you comment on them good or bad and any tips on how to improve please.
Regards Ian
