Spotmeter V calibration
Posted 31/05/2007 - 15:14
I've removed the repeat of this question to avoid cluttering the forums. It's always appreciated if any post is only made once and not spread around the forums.
Hopefully someone will be able to help you, but in the meantime just measure the meter against others and if any adjustment is needed change the ISO/ASA setting accordingly.
For example, if your meter reads 1 stop over-exposure at ISO 200 then set it to ISO 400 and all will be well.
Hope that helps.
Hope that helps.
Does anybody know where I could find information on how to calibrate a Spotmeter V?
Thanks,
Stephane
